Water, AC Vents?
Old Jul 31, 2006 | 11:04 AM
Maness's Avatar
Default Water, AC Vents?
So the other day I was driving around and some times when I would make a turn in either direction water would spit out of my floor vents (I think, I doubt it would just be in the dash) and onto the floor. This was repeatedly happening throughout the day.
I hadn't realized how much water had actually come out, or if more had come out while its been sitting there, but my car smells like wet ******* dog.
Where the hell did this water come from?
Old Jul 31, 2006 | 11:44 AM
steelrainwarrior's Avatar
Default Re: Water, AC Vents? (Maness)
mine did that too for a while...by the way anybody know how much it costs to replace a cracked a/c compressor?
Old Jul 31, 2006 | 12:03 PM
sarahsuchy's Avatar
Default Re: Water, AC Vents? (steelrainwarrior)
mines leaking.....ive called 3 different auto part stores....rebuilt ones are ranging from about $370 - 300.....
know anything about a switch in the back of the dash to fix the thermostate?
Old Jul 31, 2006 | 01:08 PM
instructor74's Avatar
check the ac drain tube on the fire wall these things get clogged and the water can't run out. So it just fills up the box and spills out when you turn. pop the hood and look for a 1/2 rubber tube comming out of the fire wall heading to the ground. use something thin to unplug the tube
darkestfenix
Jun 24, 2010 09:36 PM
osseb
Honda S2000
Aug 9, 2008 09:10 PM
mandymoo2182
Jul 25, 2008 05:25 PM
gtowni3
Oct 5, 2004 06:19 PM
GTScott
Feb 2, 2004 07:32 PM
