CRX (EE8) EDM VT 1.6L Axles?
Old Jul 31, 2006 | 03:29 AM
Keebler's Avatar
Default CRX (EE8) EDM VT 1.6L Axles?
Anyone know if there is a direct replacement axle (usdm) that would work with the EE8 EDM Crx?
I was reading about the different axles needed for the conversions/swaps using the integra axles, etc.. but since mine is stock with the 1.6 im not sure what really would work.
Id rather order something from the states, as its much cheaper than buying locally. Any help would be appreciated
TIA
~Keebs
Old Jul 31, 2006 | 04:07 AM
bfuller's Avatar
Default Re: CRX (EE8) EDM VT 1.6L Axles? (Keebler)
Whichever axles you Americans use for CRX B series swaps will work fine.
Old Jul 31, 2006 | 04:56 AM
Keebler's Avatar
Default Re: CRX (bfuller)
Well i read that some people had to change the hub ends or something in order for the integra axles to work.
Just trying to get clarification.
Old Jul 31, 2006 | 04:59 AM
SETI20's Avatar
Nope, the B-series swap axles work fine.
On the other hand, you probably don't even need axles.
The boots are about €15 a piece here in europe, and the joints between €70-80.
Usually the outer joints go bad. I've rarely seen an inner joint go bust. Unless you have 300horses or something, you'll be fine replacing just the CV joints.
Old Jul 31, 2006 | 05:00 AM
Keebler's Avatar
Default Re: (SETI20)
Yea, i replied to your pm
Figure i can get some part numbers maybe and just do it myself then. Guess if i can do an ls 5th swap, i can do some greasy cv's :D
Old Jul 31, 2006 | 05:18 AM
SETI20's Avatar
No you can't [waves hand like jedi] you need my help so I can see your projects.
Old Jul 23, 2017 | 09:36 AM
PuertoRiCuts's Avatar
So what USDM Axles did you end up using? I'm having the same problem now
Old Jan 15, 2021 | 03:12 AM
Hondacrx1's Avatar
Raxles driveshafts fit perfect
BoOsTiN Dc2
Jul 11, 2005 10:15 AM
Double_Clutchin
Apr 12, 2005 08:41 PM
JDMotive
Aug 4, 2004 08:54 AM
