Tuning w/ different manifolds
ssautochrome to maybe a ram-horm. or maybe even a log style. whatever i can get a deal on. so what if it's about the same spool time and same lbs of boost. i won't need a retune will I?
if u go from log to ram horn or any type of tubular manifold u will need retune, AF is going to be off, just like i had to, went from log to ram horn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC Vtec Turbo »</TD></TR><TR><TD CLASS="quote">ssautochrome to maybe a ram-horm.</TD></TR></TABLE>
I just retuned a ssautochrome to a full-race manifold. It would about a full point off on the a/f. Retune it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer »</TD></TR><TR><TD CLASS="quote">
I just retuned a ssautochrome to a full-race manifold. It would about a full point off on the a/f. Retune it.</TD></TR></TABLE> did it run leaner or richer? also how much power increase?
you need to take into consideration how efficient the setup was before, to how efficient the setup will be w/ the new setup.
if its a mellow setup, chances are it wont change much.
if its wild, then yes, it can.
no matter what, i would atleast toss a wideband on the car and see for yourself.
spoolin turbo s
Dec 2, 2007 05:30 AM
donkiman
Oct 8, 2004 08:57 AM
