anyone with any FIRST hand experience with the OBX ramhorn manifold?
Old 12-01-2007, 11:10 AM
spoolin turbo s's Avatar
Default anyone with any FIRST hand experience with the OBX ramhorn manifold?
anyone?
Old 12-01-2007, 11:13 AM
wade's Avatar
Default Re: anyone with any FIRST hand experience with the OBX ramhorn manifold? (spoolin turbo s)
you get what you pay for.
/endthread.
Old 12-01-2007, 11:36 AM
coneheadsracing's Avatar
Default Re: anyone with any FIRST hand experience with the OBX ramhorn manifold? (wade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade &raquo;</TD></TR><TR><TD CLASS="quote">
/endthread.</TD></TR></TABLE>
hahahhaha
Old 12-01-2007, 11:00 PM
spoonhatchblack's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade &raquo;</TD></TR><TR><TD CLASS="quote">you get what you pay for.
Lets keep it real.....
I don't mind opening to this discussion... I personally used two....that's 2 of there ramhorn mani's and there not as bad as what you think..Ran it in my DD and Blew out 400WHP Pump..
Facts:
It doesn't have quality in the welds inside the collectors (im being honest here) but the DP is def. quality....
second is you gotta run the 40mm WG..which blows ...but it relieves a bit better than the 35/38mm WG...
Anyways hope this info helps out..
Old 12-02-2007, 03:31 AM
atec's Avatar
Had two just to try them out.
1. on a d15z6 (aka minime)civic produced 223,5whp on stock engine at 14psi
ran it up to 28psi, after 3weeks the elbow(where the WG) were fitted broke of.
rewelded it.
Two weeks later the same started to happend just right after the weld(bad quality SSteel.
Shortened the length of the elbow and fitted a bracket under it to support.
Now it works fine.
2. Had it on a b18teg that produced 421,7whp at 20psi boost.
after 3000miles it cracked at the welds of the collector.
buy yourself a good manifold the first time..
Get yourself Full-race
Old 12-02-2007, 05:30 AM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: anyone with any FIRST hand experience with the OBX ramhorn manifold? (atec)
there are enough threads on this and the other manifolds. ithink you got your answer.
they work for some, and not for others. but they dont work for the vast majority.
M7EG6
12-01-2007 09:30 PM
portaman03
Honda Civic (2001 - 2005)
14
04-23-2007 06:01 AM
b00stedbyFastrax
06-05-2006 02:42 PM
donkiman
10-08-2004 08:57 AM
Universal Magnetic
05-27-2004 04:09 AM
Quick Reply: anyone with any FIRST hand experience with the OBX ramhorn manifold?
