OEM XM SAT Antenna on Aftermarket Sirius Tuner/Receiver
after many different attempts at making an adaptable coax piece for the proprietary Honda XM antenna coax lead termination, i've found, through the combination of multiple RF connector parts, a solution that will enable one to use their OEM XM Honda/Acura antenna on aftermarket tuners or receivers.
some Honda/Acura have a Single lead:
others have a Dual lead:
either way, it will be necessary to remove the connector housing to expose the actual connector jack inside:
once the connector housing is removed, the assembly of my parts can begin:
adapter cable terminated in a RA SMB plug for the majority of car docks and direct tuners, however i can terminate to whatever your tuner or car dock accepts:
copper collar and shrink tubing:
assembly:
then i place a shrink tubing sleeve over the connector body, shrink it with some heat, and you're done:
i also make a TRUE OEM Plug-and-Play version that simply requires you to unplug your antenna jack from the OEM XM Sat Tuner and plug it into my adapter cable, and it comes in two pieces- one for the adapter cable and the other, a 20 foot extension coax for interfacing with your aftermarket SAT receiver:
if anyone is interested in using their OEM XM roof-mounted SAT antenna for their aftermarket tuner on any pre-installed Honda/Acura model, please email me. Brian-
mrbrianrwebb@comcast.net
assembly:
what? isn't it a place to post to help others. and if i offer it for cost i can't post? i don't understand the forum rules then.
i appreciate the negativity. please remove this post from the forum.
pityocamptes
29
Feb 8, 2014 06:44 AM
Ryan_C
14
Jul 31, 2012 03:43 PM
2006, accord, aftermarket, antenna, brianrwebb, honda, mrbrianrwebbcomcastnet, oem, plug, ra, sat, smb, tuner, tuners, xm
