damnit!!! overheating again, wut you think?
anyways, on the way home from work last night i look down at my gauges and notice the temp, was all the up to H and wasnt coming down, i said WTF!! and pull over. i checked my radiator, the cap, the reserve,and everything looks fine, on account there new, so no sign of a leak anywere, the fan is still running, and theres water, im thinking theres no circulation, and the water pump may have gone out. wut you think?
-PinoyCivic
-PinoyCivic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinoyCivic »</TD></TR><TR><TD CLASS="quote">anyways, on the way home from work last night i look down at my gauges and notice the temp, was all the up to H and wasnt coming down, i said WTF!! and pull over. i checked my radiator, the cap, the reserve,and everything looks fine, on account there new, so no sign of a leak anywere, the fan is still running, and theres water, im thinking theres no circulation, and the water pump may have gone out. wut you think?
-PinoyCivic</TD></TR></TABLE>
thats possible, are you sure that their isnt any air in the system? did you burp it? is the t-stat working well?
yea i burped it, its not like brand new, i mean i have had htese thing on there for a little bit, and im pretty sure the stat is working, i dunno ima go check it today, but im still open for suggestions. thanks
-PinoyCivic
-PinoyCivic
maybe you need to change your fluid to a better mix
odds are its your water pump though. when water pumps go youll generally see them leak out the weaping holes. the result is a small puddle under your cars driver side close to the tire.
you can try testing the thermo but my money is on the water pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morning Call »</TD></TR><TR><TD CLASS="quote">maybe you need to change your fluid to a better mix
you can try testing the thermo but my money is on the water pump</TD></TR></TABLE>
bro, are you pinoy?
check the thermostat.. if you're in the philippines, just remove it.. you wont be needing it since we dont have "cold starts" in the philippines.. my civic used to overheat and it turns out the my thermostat's busted and stops the circulation of water..
sqeeze the hose that runs from the radiator to the thermostat close to the thermostat a few time rapidly and see if you can hear the thermostat ingaging youll hear a lil clicking sound and then if you do hear the sound then it will obviously be your water pump
