iacv or iac valve on a obd0 b16a swap in a crx?
Old Jul 29, 2006 | 03:09 PM
88crx1589's Avatar
Default iacv or iac valve on a obd0 b16a swap in a crx?
I think my iacv is bad because that is what code the ecu is shooting. The check engine light does not stay on though. It only comes on occasionally. The idle speed also varies and thats the other reason i think the iacv is bad. The idle depends on the time of day and how hot it is outside. Thats how it seems at least. If you do think its bad let me know. Where could i get a new one to fit my wiring and the motor because the motor and ecu are obd0? I have my d16 that came out of my crx that the new motor is now in. Could i swap the d16's valve with the one on my b16?
Old Jul 29, 2006 | 03:17 PM
B16CRXT's Avatar
Default Re: iacv or iac valve on a obd0 b16a swap in a crx? (88crx1589)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx1589 &raquo;</TD></TR><TR><TD CLASS="quote">I think my iacv is bad because that is what code the ecu is shooting. The check engine light does not stay on though. It only comes on occasionally. The idle speed also varies and thats the other reason i think the iacv is bad. The idle depends on the time of day and how hot it is outside. Thats how it seems at least. If you do think its bad let me know. Where could i get a new one to fit my wiring and the motor because the motor and ecu are obd0? I have my d16 that came out of my crx that the new motor is now in. Could i swap the d16's valve with the one on my b16?</TD></TR></TABLE>
you have to buy a iacv from a 95 del sol dohc vtec at Honda. your IACV is bad. non obd b16's all have that problem with how old they are. Try leaning it with carb cleaner first...
usdmEHboy
10
Nov 14, 2007 10:21 AM
lsvtecek18
Mar 5, 2005 09:27 PM
crexer
Jan 15, 2005 09:46 PM
acidx
Jun 5, 2004 02:15 PM
