GSR-- Swap or Re-build...
Old Apr 23, 2002 | 08:24 AM
Papa-VTEC's Avatar
Default GSR-- Swap or Re-build...
I have a stock B18C1 motor with 141,k on it and cant decide whether to swap the motor or just rebuild it, and i have no idea where to go to do either in south-jersey
just need some ideas
Old Apr 23, 2002 | 10:18 AM
deviant94ex's Avatar
New User
Default Re: GSR-- Swap or Re-build... (Papa-VTEC)
thats kind of odd that you have te same username as another member here used to have (14eight). he is form CT though. if you want to get rid of the mileage factor on your engine you should just rebuild it. while your at it you can put in higher compression pistons, forged rods, etc for N/A or low compression pistons and such for a turbo application. may as well rebuild it stronger than stock. good luck.
CHRIS
Old Apr 23, 2002 | 12:10 PM
harryg's Avatar
Default Re: GSR-- Swap or Re-build... (deviant94ex)
Miles aren't very indicative of condition on Honda motors. Run compression/leakdown tests.. if everything comes out well then you have more time to work with. Hell, as long as the block is in good condition you could get it re-sleeved, bored, and have other blockwork done to it and turn it into a boost monster!
Nyrudeboy
Sep 6, 2007 06:47 PM
digital sol
Jan 1, 2006 10:59 AM
kid-crx
Apr 19, 2005 07:16 PM
jdmstreethatch
Feb 5, 2005 09:21 AM
deceit
May 17, 2002 06:07 PM
