problem, second gear grinding....
Old Jul 29, 2006 | 01:27 PM
igotboost's Avatar
Default problem, second gear grinding....
I changed my trany, just recently put a type R in. new flywheel,. new clutch, new pressure plate., new throw out bearing, new pilot bearing. n im seriously tired fo spending money, n now second gear grinds. i was wondering if the slave cylinder was bad, would it allow it to grind any gears... drives fine, just afradi the fact that vrything is brand new n i dont know whats goin on.. any suggestion would be deply appreciated.. thanks..
Old Jul 29, 2006 | 02:21 PM
onepoint6i's Avatar
Default Re: problem, second gear grinding.... (igotboost)
only second gear? when shifting normal,hard,both?
sounds like you have a broken shift fork or bad synchro inside that tranny..
Old Jul 29, 2006 | 05:00 PM
SkRiBLaH's Avatar
2nd gear = expensive to fix
3/4 gear syncro hub/collar is $162.
1/2 is like 250...
Old Jul 29, 2006 | 06:23 PM
igotboost's Avatar
shifting second hard or soft, no matter how, still grinds..
Old Jul 30, 2006 | 05:50 PM
igotboost's Avatar
Default Re: (igotboost)
Bump for some assistance
Old Jul 30, 2006 | 06:14 PM
onepoint6i's Avatar
pull the tranny and take it apart..you're gonna have to..
Old Jul 30, 2006 | 06:23 PM
Honda Bull's Avatar
Default Re: (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">pull the tranny and take it apart..you're gonna have to..</TD></TR></TABLE>
Could be shift fork. Could be something else. Make sure tranny fluid is full. That don't work, just double check the slave cylinder's movements and make sure it functions properly.
Then pull the tranny if all else fails.
I'm just now getting this problem. Going into 2nd at 8200 rpm, my tranny has grinded/locked out four times in the past three times at the track. It runs fine without beating the hell out of it... but I'd like to hit up the track some more before I leave for Japan.
godruler
Aug 13, 2006 10:15 AM
charjacq
Jul 27, 2004 01:13 PM
sshaikh01
17
Mar 6, 2003 06:27 PM
is3oo
Jun 6, 2002 10:10 PM
