is it possible to tap here for an oil temp sending unit???
Old Jul 29, 2006 | 12:07 PM
blackeg's Avatar
Default is it possible to tap here for an oil temp sending unit???
just wondering if i can put the sender for an autometer oil temp gauge in this spot on the head. i know it gets oil in it and doesnt get in the way of moving parts. anyone done it before?
Old Jul 29, 2006 | 12:11 PM
komat's Avatar
Default Re: is it possible to tap here for an oil temp sending unit??? (blackeg)
i believe if you tap it there. you will only see oil pressure when vtec comes on
Old Jul 29, 2006 | 12:20 PM
Blaze45's Avatar
Brrraaaap!
Default Re: is it possible to tap here for an oil temp sending unit??? (komat)
Just tap the pan, easier IMO. I had mine tap'd n tig'd w/ a bung for $20!
Blaze
Old Jul 29, 2006 | 03:06 PM
dunkd's Avatar
Default Re: is it possible to tap here for an oil temp sending unit??? (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Just tap the pan, easier IMO. I had mine tap'd n tig'd w/ a bung for $20!
Blaze</TD></TR></TABLE>
you tapped the oil pan for the pressure sender?
Old Jul 29, 2006 | 03:11 PM
platinum00's Avatar
why not just do what most do and t off the OEM pressure sensor.
platinum.
Old Jul 29, 2006 | 03:18 PM
Blaze45's Avatar
Brrraaaap!
Default Re: is it possible to tap here for an oil temp sending unit??? (platinum00)
haha whoops I thought he was sayin oil TEMP* my bad.....
turbotime's Avatar
Default Re: is it possible to tap here for an oil temp sending unit??? (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">
you tapped the oil pan for the pressure sender?</TD></TR></TABLE>
nah he said *temp* sender
Old Jul 29, 2006 | 03:21 PM
Blaze45's Avatar
Brrraaaap!
Wait.... it is for an oil temp sender.... lol
Old Jul 29, 2006 | 03:23 PM
turbotime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Wait.... it is for an oil temp sender.... lol </TD></TR></TABLE>
hahaha
Old Jul 29, 2006 | 03:53 PM
blackeg's Avatar
Default Re: is it possible to tap here for an oil temp sending unit??? (turbotime)
hahahaha. temperature! oil temp.
anyhow, the T thats currently being used off the back of the block is all full and i dont feel like making a huge contraption of brass fittings, or even than buying another T haha
Old Jul 29, 2006 | 04:42 PM
NJIN BUILDR's Avatar
The standard that people generally go by is oil pan temperature.The oil temperature varies in the engine, so if you measure it elsewhere it will be hard to compare with others that measure it in the pan.I've tapped the drain plug before (in the side of the pan,not the bottom).It just a pain when you change the oil.
Old Jul 29, 2006 | 11:03 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">hahahaha. temperature! oil temp.
anyhow, the T thats currently being used off the back of the block is all full and i dont feel like making a huge contraption of brass fittings, or even than buying another T haha</TD></TR></TABLE>
You need an oil filter sandwich.
Old Jul 30, 2006 | 08:09 AM
blackeg's Avatar
Default Re: is it possible to tap here for an oil temp sending unit??? (Sleeper Style)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style &raquo;</TD></TR><TR><TD CLASS="quote">
You need an oil filter sandwich. </TD></TR></TABLE>
ya i have on on my car. its badass but i use the an fitting for my lsvtec oil feed. this car is a gsr...do they sell a plug for that an larger hole?
Old Jul 30, 2006 | 08:18 AM
RTW DC2R's Avatar
temp sender drain plug FTW
DC4_MADMAN
May 26, 2006 01:37 PM
CivicMike
May 26, 2005 09:34 AM
KStuned
Mar 13, 2004 12:33 AM
BoostedH23a1
Oct 24, 2002 07:56 AM
