Need help with injectors..
Old Jul 29, 2006 | 09:46 AM
lilcrxgurlie's Avatar
Default Need help with injectors..
I have an 89 crx with ls vtec swap and i need to find the best injectors to use, people have told me 3 different kinds now and i need help
Old Jul 29, 2006 | 08:01 PM
EF_LSVtec's Avatar
Default Re: Need help with injectors.. (lilcrxgurlie)
what kind of mods do you have on your motor? How much power are you putting out? I was running stock 91 LS injectors up until I made power over 220whp, then I switched to a DSM 440 (stock injectors of turbo VR4 Mitsubishi Galant).
Old Aug 1, 2006 | 09:21 AM
Default Re: Need help with injectors.. (EF_LSVtec)
Its about 170-180 hp, dont really have many mods to the motor. Just have skunk2 intake mani, aem cold air, type r cams, etc. i was told 350cc, 310cc and 270cc..
Old Aug 1, 2006 | 09:47 AM
ED7's Avatar
ED7
You probably could get by with the 240's. What are you using to tune? If the duty cycle is too high with the 240's, then going slighty bigger would be what you need.
Old Aug 1, 2006 | 09:48 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Need help with injectors.. (ED7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED7 &raquo;</TD></TR><TR><TD CLASS="quote">You probably could get by with the 240's. What are you using to tune? If the duty cycle is too high with the 240's, then going slighty bigger would be what you need.</TD></TR></TABLE>You are right he'll be ok.
240s will be fine don't mess around with other stuff.
Old Aug 2, 2006 | 06:25 PM
Default Re: Need help with injectors.. (***-assin)
Thanks, will get those then. Are the Venom ones from summitracing.com any good?
Old Aug 2, 2006 | 06:36 PM
Crx Jimmy's Avatar
the stock injectors are fine, dont waste your money. you can go at least 200whp before needing any upgrade
Old Aug 2, 2006 | 10:20 PM
ED7's Avatar
ED7
Default Re: Need help with injectors.. (Crx Jimmy)
I don't know about the venom injectors, and would not buy them. I would try to find oem.
Old Aug 14, 2006 | 09:34 PM
JDMisGOOD's Avatar
What engine management?
LILSOWEK
Oct 18, 2006 04:08 PM
nokturnal_munkeeboy
Jun 23, 2006 01:38 AM
bootlegtrader
10
Sep 19, 2005 05:40 AM
Battle Cat
Jan 18, 2005 08:28 PM
b16powwer
Aug 15, 2003 12:07 AM
