need help with injectors ????
Old Jan 12, 2005 | 09:55 PM
Battle Cat's Avatar
B A N N E D
Default need help with injectors ????
i putting together my ls turbo and i was wondering if u guys kind help me out by getting the rigth injectors. should i get 400 cc or more, someone told me that i could use stock wrx injector ?? will they fit rigth or no ?? thnak guys for all your help !!!
Old Jan 12, 2005 | 09:59 PM
98lude-t's Avatar
Default Re: need help with injectors ???? (Battle Cat)
need a whole lot more info than that? no subaru injectors.
Old Jan 12, 2005 | 10:46 PM
ScottEK's Avatar
Default Re: need help with injectors ???? (98lude-t)
You're probably talking about the JDM WRX injectors that you can cut the diaphram off of. You end up with an injector that doesn't have a correct flow pattern but you are getting around 800cc. If you go that route you'll need to get the wire harness off a subaru, I actually have some if you're interested.
Old Jan 12, 2005 | 10:54 PM
triple_s1x's Avatar
Default Re: need help with injectors ???? (beta13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 &raquo;</TD></TR><TR><TD CLASS="quote">You're probably talking about the JDM WRX injectors that you can cut the diaphram off of. You end up with an injector that doesn't have a correct flow pattern but you are getting around 800cc. If you go that route you'll need to get the wire harness off a subaru, I actually have some if you're interested.</TD></TR></TABLE>
I dont know maybe those injectors are different from what i'm used to seeing on subarus. I know the wrx and the 2.5rs both have injectors that are about half the size of normal bseries injector. So i dont think they will fit, unless the jdm piece is different.
Old Jan 14, 2005 | 11:04 PM
Battle Cat's Avatar
B A N N E D
cool then so which injectors should i go with ???
Old Jan 14, 2005 | 11:15 PM
ScottEK's Avatar
Default Re: need help with injectors ???? (triple_s1x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by triple_s1x &raquo;</TD></TR><TR><TD CLASS="quote">
I dont know maybe those injectors are different from what i'm used to seeing on subarus. I know the wrx and the 2.5rs both have injectors that are about half the size of normal bseries injector. So i dont think they will fit, unless the jdm piece is different. </TD></TR></TABLE>
You are talking about side feed injectors.
Old Jan 15, 2005 | 09:15 PM
Battle Cat's Avatar
B A N N E D
no , the reg. ones but if they dont fit which ones should i get ??
Old Jan 16, 2005 | 11:43 PM
ForcedEk9's Avatar
RC 440's
Old Jan 17, 2005 | 11:51 PM
Battle Cat's Avatar
B A N N E D
Default Re: need help with injectors ???? (ForcedEk9)
thanks guys !!
Old Jan 18, 2005 | 06:54 AM
SOHC_MShue's Avatar
screw the rc 440's unless you got a lot of extra money laying around. You can't beat a set of dsm 450cc's for $50. All you gotta do is wire in a resistor box.
Old Jan 18, 2005 | 08:28 PM
Battle Cat's Avatar
B A N N E D
Default Re: need help with injectors ???? (SOHC_MShue)
cool man thanks so those injector will do the job ???
prelude2121
Oct 29, 2010 02:40 PM
h22bb1
Oct 21, 2008 08:42 PM
bootlegtrader
10
Sep 19, 2005 05:40 AM
stockhatch91
Nov 22, 2004 03:59 PM
Patron
Mar 9, 2004 03:00 PM
