jdm verson of d16z6?
Old Jul 29, 2006 | 06:56 AM
commotion's Avatar
Default jdm verson of d16z6?
is that a d15 or somthing.. i wanna be able to swap so my turbo and all will fit back on... and not change much... thanks for the info in advance also will i have to change my puter i got a p28 also links with these motors would be sweet aswell..i just need a cheap one for now untill i get some real money
Old Jul 29, 2006 | 06:57 AM
Sleepy_Red_hatch's Avatar
Default Re: jdm verson of d16z6? (commotion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by commotion &raquo;</TD></TR><TR><TD CLASS="quote">is that a d15 or somthing.. i wanna be able to swap so my turbo and all will fit back on... and not change much... thanks for the info in advance also will i have to change my puter i got a p28 also links with these motors would be sweet aswell..i just need a cheap one for now untill i get some real money
i believe its the D15B vtec (since there is a Vtec version, a Vtec-E version and a non-vtec version)
Old Jul 29, 2006 | 07:00 AM
95jeremie's Avatar
Default Re: jdm verson of d16z6? (Sleepy_Red_hatch)
no the jdm d16z6 is the SOHC ZC
the d15b is a 1.5 and the z6 is a 1.6
Old Jul 29, 2006 | 07:02 AM
commotion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">i believe its the D15B vtec (since there is a Vtec version, a Vtec-E version and a non-vtec version)</TD></TR></TABLE>
whats the vtec-e and vtec whats the diff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jeremie &raquo;</TD></TR><TR><TD CLASS="quote">no the jdm d16z6 is the SOHC ZC
the d15b is a 1.5 and the z6 is a 1.6</TD></TR></TABLE>
so im looking for a d16z6 or d16zc? im confused
Old Jul 29, 2006 | 07:03 AM
95jeremie's Avatar
Default Re: jdm verson of d16z6? (95jeremie)
and any d serries will bolt up with the turbo
Old Jul 29, 2006 | 07:18 AM
95jeremie's Avatar
the USDM d15b is non vtec
the JDM d15b is vtec
don't hang me if i'm wrong
as well as if you are talking about the "d15b" it is the JDM one
the USDM codes have a number after them "d15b7"
Old Jul 29, 2006 | 07:20 AM
95jeremie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by commotion &raquo;</TD></TR><TR><TD CLASS="quote">so im looking for a d16z6 or d16zc? im confused </TD></TR></TABLE>
i don't think it's called the d16zc just call NewYork block and ask them they wil know
Old Jul 29, 2006 | 08:21 AM
commotion's Avatar
do you got their numba ?
Old Jul 29, 2006 | 12:01 PM
NopSpawn's Avatar
the sohc zc vtec is the jdm ver of the d16z6. So the block code would be zc with a vtec valve cover and a vtec solinoid.
Old Jul 29, 2006 | 12:21 PM
Relic1's Avatar
Default Re: (NopSpawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NopSpawn &raquo;</TD></TR><TR><TD CLASS="quote">the sohc zc vtec is the jdm ver of the d16z6. So the block code would be zc with a vtec valve cover and a vtec solinoid.</TD></TR></TABLE>
true allthough this is true also
there is a 130hp D15B which uses the same head as the Z6. but the 1.5L block
technically the ZC VTEC is the closest to the Z6. All though it's not as common as the 130hp D15B.
the D15B came in three versions that we've been able to locate.
the VTEC-E version comes with the P07 head which is the same as the VX(D15Z1) - 92hp but great mpg.
the VTEC version comes with the P28 head which is the same as the EX/SI(D16Z6) - 130hp
the non-VTEC version I don't know much about but I'd bet it's a copy of the D15B7.
Old Jul 30, 2006 | 11:41 AM
commotion's Avatar
Default Re: (Relic1)
k i may just stick with what i had which was a d16z6 cause im running turbo.... cause i dont think the d15b which has higher compression would be good or would it....? i have a xtra d16z6 but im not sure if it is any good.. how would one check? i mean it seems smooth when im turning the crank but im not sure why it was taken out or whats wrong with it...i just wanna replace my motor as cheap as possable.. in like 6 months i can afford to put a better motor in..
Thanks for your time and comments...
Shaun
'90 honda crx
24
Sep 12, 2006 09:34 PM
ci_v_ic
15
Aug 17, 2006 03:28 AM
illogic65
Jun 26, 2006 11:59 AM
spoonfedcrx
15
Feb 5, 2006 01:21 PM
steve0unce
10
Nov 26, 2004 06:51 PM
