Need help, getting a ECT CEL ?? any suggestions?
sup.. i'm gettin a ect CEL problem, and i have no idea which sensor that is,, and i think that's the reason it's makin my car idle at 1500.. can anyone point me to the sensor?? i'm running a 97 civic ex coupe with a 98 gsr motor.. i used a 97 ex harness, with a obd I gsr ecu, usin a jumper harness.. any help would be greatful thanx...
[Modified by AzN_J_SpeC, 8:22 AM 4/23/2002]
The Engine Coolant Temperature sensor is on the right side of the cylinder head above the transmission. It has a two pin electrical connector going to it. The one pin sensor is for your temp. guage. Code #6, correct?
[Modified by b19coupe, 8:10 PM 4/23/2002]
i found the problem,, i had the vtec and ect plugs swapped
maybe that's y vtec wasn't engagin.. duh.. thanx for those who relpied..
sk8board{Pete}
Dec 14, 2010 11:08 AM
skUnK2jdm
30
Feb 5, 2008 11:00 AM
ek-to-tha-max
Oct 7, 2005 02:50 PM
