Suspension & Brakes Theory, alignment, spring rates....
front lower tie bar and 4-1 header clearence?
Old Jul 29, 2006 | 01:57 AM
potatostix's Avatar
Default front lower tie bar and 4-1 header clearence?
I found a DC sport 4-1 header for very cheap locally and I'm wondering if anyone's had any clearence issues with them and a front lower tie bar? It's already almost touching my 4-2-1 so I'm assuming its going to be VERY tight with a 4-1 if it'll even fit at all. Tried to search but didn't come up with anything. Any experiences or pictures would be greatly appreciated.
Old Jul 29, 2006 | 10:43 PM
FalkenSiR's Avatar
Default Re: front lower tie bar and 4-1 header clearence? (potatostix)
Try it, if it doesn't fit, then go with the integra front subframe bar. It bolts up to the front subframe. Look down where the lca's meet the subframe and you will see two holes (on each side) just sitting there. That's where the bar goes
I got mine today for $15 off a GSR and it made my handling a little bit crispier and the car feels a little tighter thru turns, specially around town.
Old Jul 31, 2006 | 09:41 AM
dohcdelsol's Avatar
Default Re: front lower tie bar and 4-1 header clearence? (fast95eg8)
its very very tight.
my motor would hit upon accelleration but after some new motor mount inserts, it doesnt touch.
neuspeed bar with 4-1 dc headers stock d16 motor.
the header will eventually melt part of the bar down. if it doesnt fit completely, have a little bit of the bar off or dont run it.
Old Jul 31, 2006 | 02:55 PM
JSPECSIR's Avatar
Default Re: front lower tie bar and 4-1 header clearence? (dohcdelsol)
i got a dc 4-1 on a b16 in a 94 hatch, mine has about 1/2-3/4 inch space between it and the header.
Old Jul 31, 2006 | 03:07 PM
Tyson's Avatar
what does this have to do with suspension? (tie bars are not even part of the suspension)
post this in integra or tech section.
akhom
Oct 12, 2004 04:12 PM
boxer0002
May 21, 2004 09:53 AM
KillerWabbit
Oct 25, 2003 07:10 PM
JDMjames
Jul 2, 2003 09:41 AM
itr98spec
Apr 2, 2003 09:57 PM
