Front lower tie bar and JDM 4-1?
I just found a Neuspeed front lower tie bar someone has apparently left in my garage over a year ago. I have a 93 Si with a GS-R... I'm wondering if this tie bar will clear my JDM 4-1 header. I searched, found nothing. Just wondering if anyone has the same setup. Thanks!
Re: Front lower tie bar and JDM 4-1? (KillerWabbit)
It should clear it but the neuspeed bar hangs really low. The good thing is, if you scrape, you will scrape the bar before the header. I have an ITR front lower bar and it's perfect, it bends over the exhaust instead of under.
Location: Toronto, Canada currently residing in ATL, GA, USA
Re: Front lower tie bar and JDM 4-1? (Kalokohan)
I have a DC JDm header which hangs lower then the OEM JDm ITR header and it rests on my Neuspeed bar slightly.
You should haven o problems with clearance.
Well, I tried to put the bar on.. it does not clear the header.
The little skid plate welded to the flange is what gets in the way. I don't think I want to cut this off since if I did come across some high ground, it would rip the flange off.
Oh well.
Oh well.
akhom
10-12-2004 04:12 PM
itr98spec
04-02-2003 09:57 PM
