vtec not working - where to start?
Old Jul 28, 2006 | 09:40 PM
2wheelhunter's Avatar
Default vtec not working - where to start?
i just swapped a jdm b16a into a 93 civic cx, i used a usdm gsr wire harness, jdm p30 ecu, the car runs fine but vtec isnt working.. where should i start to look to fix it.. wires? solenoid?
Old Jul 29, 2006 | 05:20 AM
d16vteceg's Avatar
Default Re: vtec not working - where to start? (2wheelhunter)
If you just did a swap then it's possible you wiring is off somewhere. Also check to make sure you're solenoid is getting oil. check your gasket filters and make sure they aren't clogged in any way. You might need a new solenoid if they aren't. If you know someone else with a vtec engine see if you can use theirs haha. It's kind of unconventional but it would tell you whether or not you need a new one.
swizz977
10
May 25, 2011 08:15 PM
josh's ep3
Dec 8, 2008 05:59 PM
Project.Jdm
Mar 16, 2008 06:18 PM
Naoh_97
10
Feb 14, 2005 10:40 AM
Eg6_JDM
Apr 26, 2002 10:27 AM
