Turbo blow off sound
just have to say i love the turbocharger! but i have been wonderin why doesnt it make the nice pssssssh sound when your in neutral? like on a evo all you have to do is barly get the rpms up and it makes a nice blow off noise
that noise you hear comes from built up pressure in the charge pipes, when you shift or the rpm's drop the pshhhh sound you hear is the valve taking excess pressure out of the charge pipe so the turbo doesn't have to spool down then respool, saving time and gaining speed for your car, the reason the evo sounds like it may blow off at lower rpms is b/c of the boost its running at and the setting the BOV is set to open up at
It does, u just have to wind it higher...
All turbo systems have a BOV to make that sound and releave pressure on the charge pipe...if they dont the charge air will force the butterfly open and u'll face problems of a fluttering butterfly :-\
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">It does, u just have to wind it higher...
All turbo systems have a BOV to make that sound and releave pressure on the charge pipe...if they dont the charge air will force the butterfly open and u'll face problems of a fluttering butterfly :-\</TD></TR></TABLE>
Um, no. Some turbocharged engines have diverter valves and some older turbo cars had nothing. BOVs are used to prevent compressor surge, they have nothing to due with forcing butterflies.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Surewin »</TD></TR><TR><TD CLASS="quote">
Riiiiight, okay, put a turbo on ur civic and run it a 25lbs and no BOV, tell me what happens...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbochargedcivic »</TD></TR><TR><TD CLASS="quote">why doesnt it make the nice pssssssh sound when your in neutral? </TD></TR></TABLE>
Not all blow off valves are the same... also, in neutral? I've never heard my turbo spool in neutral. So I don't even know if the BOV will even go off in Neutral.
You have a boost gauge? Ever tried revving the **** out of your motor while in neutral? You'll notice you're not even boosting.
think of a blow off valve as a huge boost leak........the louder you blow the more pressure your letting go......if you loosen up the nut on top of your blow off valve it will release more air.....if u tighten it you realese at a faster rate shorter sound but louder.........also when u releasse the throttle in nuetral you have to let go of the gas real quick other wise it will blow off slow and you probably wont hear it
you need load to create boost.
evos blow off because they have load and create boost when you rev them up. this is because of all the accessories that run of the engine and create load.
Your turbo honda maybe not have enough load to create the boost when free revving. This could be because the lack of accessories, or size of the turbo charger.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16y8_619 »</TD></TR><TR><TD CLASS="quote">... my t25 blows off in neutral</TD></TR></TABLE>
yep because it can create a little boost with the small load in neutral when you rev. It takes a lot less flow and pressure differential to spool a little turbo like that.
However changing to a smaller turbo so you can rev and blow off is the most ricer **** in the world. If you want to look cool and not loose power, upgrade to a larger motor lol
fuking ricers
fuking ricers
hahaha, yea, a Blow Off Valve is there to make a cool sound and its secondary feature is to not damage your turbo. LOL
I used to own a turbo jetta and kept diverter valve and relocated it deeper down intake tract to get rid of the noise....
The butterfly flutter is compressor surge, the fins on the turbo being spun backwards due to excess pressure not relieved in pipes. bascially rejected air fromt he throttle body back through.
Now do you hear the bov when driving
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbochargedcivic »</TD></TR><TR><TD CLASS="quote">yes i love to show off thats why i want to do it! im runnin 8 psi and yes i kno what a blow off valve is</TD></TR></TABLE>
you, sir, are the epitome of ricer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknoracing »</TD></TR><TR><TD CLASS="quote">my VW GTI 1.8t is running about 22 PSI and no BOV. It runs recirculated.</TD></TR></TABLE>
yes thats how my buddy's 1.8t also.
btw are the numbers in your sig. at 22psi?
