Headgasket Question (searches)
Old Jul 28, 2006 | 06:09 PM
TwoKSiR's Avatar
Default Headgasket Question (searches)
Is there a good headgasket for a GSR that is thicker than stock and not copper? I want to lower my compression but I am nervous using copper do to leaking problems. I would prefer a MLS. Thanks.
Old Jul 28, 2006 | 10:36 PM
TwoKSiR's Avatar
Default Re: Headgasket Question (TwoKSiR)
bump
Old Jul 29, 2006 | 10:40 PM
delsol revolution's Avatar
Maybe try a Cometic HG http://cometic.com/gaskethome.aspx
Old Jul 30, 2006 | 02:27 AM
dmacaalay's Avatar
Default Re: Headgasket Question (delsol revolution)
on the cometic.. they make custom gaskets..
Old Jul 30, 2006 | 06:52 PM
TwoKSiR's Avatar
Default Re: Headgasket Question (dmacaalay)
But wouldnt a cuspot gasket be expensive?
Old Jul 30, 2006 | 07:44 PM
boost'd_crx's Avatar
go with cometic
Old Jul 31, 2006 | 12:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwoKSiR &raquo;</TD></TR><TR><TD CLASS="quote">But wouldnt a cuspot gasket be expensive?</TD></TR></TABLE>
Do some research and find out
Old Jul 31, 2006 | 11:50 PM
TwoKSiR's Avatar
Right now with an OEM 3 layer my compression will be around 11.76:1.
I also have Omni valves and he said the the flat face will add 0.4:1.
I also have about 8 milled off the head. What thickness will I have to run to get my compression in the mid to low 11's? Thanks.
Slow_import
Feb 16, 2010 07:47 PM
xyzalvarez
31
Sep 5, 2005 09:54 AM
btrim23
Apr 27, 2004 01:08 PM
2kflamedlude
Apr 25, 2004 06:01 AM
Wide Open Throttle
Feb 25, 2004 07:27 PM
