high idle
ok so i have a B18B1 OBD 0 in my crx and i just recently installed a nitrous kit. yesterday was the first time i sprayed, everything seemed fine until i started slowing down my idle was way high 30-35 and it stayed that way for a while so i just quickly left my location and went home it was night time already so i had no choice but leave it be and wait till sun up so i woke up this morning and started the car nothing wrong idle was normal... so i was wondering if any of you guys had the same experience/problem and can help me fix it i will not spray again until i get some more info if any of you guys have feed back it would be much appreciated thanks
not sure if thats it i have checked thousands of times to see which wire on my tps needed to be wired up with the kit and i think i have the right one
but i will check again doesnt hurt to check
ok so i havent spratyed again but my car does have a high idle... around 20-25 any suggestions info...
Modified by lCHaCHeel at 2:43 PM 7/29/2006
spray carb cleaner around all the gaskets with the motor running, the idle will change if there is a hole and the cleaner gets in, easy way to tell. also make sure your idle screw did not fall out, my buddy's car had that problem, also maybe your IACV is stuck open?
i got a zex 50 dry shot with an auto bottle opener and a purge kit and i replaced the IVAC on it cuz i had the same problem, try it and Ivac is like 50 buckz or somethin.................... just my 2 cents.
