f22 frankenstein
Old Jul 28, 2006 | 01:19 PM
rohec04's Avatar
Default f22 frankenstein
i was wondering if i use the h22 connecting rods on the f22 crank, h22 piston will the
piston knock on the head?
Old Jul 28, 2006 | 05:32 PM
.BigSexy's Avatar
most hood white kid
Default Re: f22 frankenstein (rohec04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rohec04 &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering if i use the h22 connecting rods on the f22 crank, h22 piston will the
piston knock on the head?</TD></TR></TABLE>
i believe u have to use the f22 connecting rods. with stock cams and the head not milled, clearance should be fine, but when you start milling and getting more aggressive cams, then you might run into something. you should try claying your motor to check clearance...
let me search to fin you a write-up
Old Jul 28, 2006 | 05:37 PM
.BigSexy's Avatar
most hood white kid
im at work right now...it wont let me copy and paste so do this...
search "clay" in the archives in the All Motor forum, then click the second to last thread, there are only 7, and there is a link in there with a how to:
bigdaddyvtec
Feb 24, 2012 03:54 PM
big_mac45
17
Nov 21, 2011 07:54 PM
michaelprice83
Feb 16, 2009 09:27 AM
MadCityLude
Jul 15, 2006 12:07 PM
912
Mar 9, 2006 12:10 AM
