car not starting!!!
I just put a new dizzy in my car and when I went to start it up, it turn over a couple of couple of times but did not start.then it stop turning over .I've checked all the fuses,grounds etc..I hear the fuel pump priming but its not even turning over.like its dead!u guys have any ideas of what else it could be?
this issue is prob. unrelated to your dizzy, do your dash lights come on, was the car cranking slow or normal? check the conn. at the batt., starter, and so on.
I've checked all that it everything seems fine.light go on (w/no dimming)all connections are tight.I will putting my old dizzy on today to see if it turns on.but the wierd thing is that its not even cranking over???thats whats got me puzzzled
I will let u guys know how it goes.thanks
Did you check the firing order, check if all your injectors and all your harnesses for the distributor are hooked up. Also make sure that you have the distributor timed right.
ok so i put my old dizzy and checked my battery.battery is fine.still nothing.seems like no power is going thru to turn the engine.???Is there any whay to check my main relay?maybe thats it.but i hear the fuel pump prime when i turn the ignition on.weird.anything else u guys think it might be???
maybe ur starter went out...*shrugs* you could go find a friend with one of those hand starters(connects one cable to the starter and one to the battery) just so you dont waste money buying new **** you dont need..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleakdragonmage »</TD></TR><TR><TD CLASS="quote">maybe ur starter went out...*shrugs* you could go find a friend with one of those hand starters(connects one cable to the starter and one to the battery) just so you dont waste money buying new **** you dont need..</TD></TR></TABLE>
yes i think your starter's out hit it and see what happens or can be ur alter
jdmekrobot
Jul 3, 2009 06:20 PM
