OBD1 conversion in a 99 civic si
Old Jul 28, 2006 | 04:46 AM
miahjera04's Avatar
Default OBD1 conversion in a 99 civic si
i have a 99 civic si, and i bought skunk 2's obd2-obd1 conv. harness. and i bought a chipped p28 ecu. and everythig works like it should, the redline changes, the air/fuel curves r there, the only thing, is that v-tec wont engage at all anymore??? any ideas???
Old Jul 28, 2006 | 08:17 AM
bonylad's Avatar
Default Re: OBD1 conversion in a 99 civic si (miahjera04)
Does it work with your old ecu? If yes then the new one is not working
correct.
Old Jul 28, 2006 | 08:49 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: OBD1 conversion in a 99 civic si (bonylad)
Pretty much covers it.
Old Jul 28, 2006 | 08:56 AM
fmrprojects's Avatar
Default Re: OBD1 conversion in a 99 civic si (black_EM1)
see what the vtec engagment is on the chipped p28. maybe its at a higher rpm and you really cant hear it. try getting another chip with the vtec at 5200 and see if vtec works with that
Old Jul 31, 2006 | 03:11 PM
miahjera04's Avatar
its not the harness thats the problem, i think its the ecu, is there anouther way to find out for sure tho?
Old Jul 31, 2006 | 03:37 PM
slowSOHCvtec's Avatar
get a buddy's ECU that you know works and see if your vtec kicks in, if you don't know what it sounds like you can always hook up a small LED to the fuse that goes to the solenoid and it will be a simple test...
stagen
Engine Management and Tuning
Nov 19, 2009 07:46 AM
mpls
Feb 2, 2009 01:31 PM
brownman72000
Nov 8, 2002 07:44 AM
