B20 swap help
Old Jul 28, 2006 | 12:58 AM
sketchaholic's Avatar
Default B20 swap help
I have a 93 civic that I am putting a b20 in. If i want to use my civic harness do I have to use the injectors from my civic also? Thanks in advance.
Old Jul 28, 2006 | 01:07 AM
JDMlyfestyle's Avatar
Noo because D series injectors are different than b series injectors. you need to find some OBDI B Series injectors.
Old Jul 28, 2006 | 01:51 AM
inline4's Avatar
Default Re: B20 swap help (sketchaholic)
depends.. all b-series and some d-series injectors are 240cc.
the d-series ones that are iffy are VX and CX, some say they are rated at 190cc others say they are not.
all d-series that come with VTEC (d16z6, etc) are 240CC
Old Jul 28, 2006 | 02:02 AM
knockout's Avatar
i wouldnt, even if they are about the same (i have no idea), i wouldnt want to risk 1.6L engine injectors running a 2.0L engine. just for piece of mind.
Old Jul 28, 2006 | 10:41 AM
anybody else?
Old Jul 28, 2006 | 10:49 AM
inline4's Avatar
Default Re: (sketchaholic)
all d and b-series injector flow at 240cc. the ecu determines whether they flow at 180, 190, 235 or 240 at full cycle. that's a short summary of what i just searched.
kinda makes sense since every other honda part is interchangeable (map sensors, tps sensors, iat sensors, some o2 sensors)
however, i could not find a definitive answer.. just random babbling, but that one seemed like the best answer i read.
Old Jul 28, 2006 | 12:08 PM
JDMFreak's Avatar
i might be wrong on this, but check your clips on your injector, i have an OBD1 in a OBD2b car, but i am using OBD1 injectors with OBD2b harness...if that make sense, but do you still have the stock injectors off of the B20? i would assume that the D-series would fit as long as the clips are correct i hope this help.
Old Jul 28, 2006 | 10:43 PM
Thanks for the suggestions guys. I'll check the clips out.
94db7vee
Jun 18, 2012 05:52 AM
SBA-EG6
13
Apr 5, 2007 10:04 PM
da egg
Nov 6, 2006 06:45 PM
jAUTOek4
Jun 21, 2006 11:54 PM
gotjesus
Nov 2, 2003 12:18 PM
