bkr7e's whats the highest hp before going to 8's
i was wondering when you should switch out the bkr7e's for some 8's i have a built lsvtec running s t3 60-1 making about 400whp at 14 psi 91 octane and about 550whp on race gas 25psi?
should i always run the 8's or run the 8's for race gas and the bkr7 for pump??
Run 8's, maybe 9's. The worse that can happen if they are too cold is it will foul out or run crappy. But if they are too hot, then detonation and bad things will happen... you get my point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Run 8's, maybe 9's. The worse that can happen if they are too cold is it will foul out or run crappy. But if they are too hot, then detonation and bad things will happen... you get my point.</TD></TR></TABLE>
good advice
spark plugs are cheap, i'd probably pick up a few sets of 8's and 9's and see what works best for you.
good advice
97grnrs
Dec 11, 2006 09:56 AM
