Suspension & Brakes Theory, alignment, spring rates....
Bad setup???
Old Jul 27, 2006 | 03:03 PM
Blacklabel182's Avatar
Default Bad setup???
I have a daily street-driven 94 LS Integra, and currently have APC coilovers with AGX adjustable shocks. Should I ditch this setup?
Old Jul 28, 2006 | 12:05 AM
dude_123's Avatar
Default Re: Bad setup??? (Blacklabel182)
If this setup works for you and you feel comfortable with it then it is not for other's to give their opinion because every individual has their own "taste." Or unless you wanted a more streetable, less bouncy ride, etc, etc.
Old Jul 28, 2006 | 12:44 AM
Tornadom's Avatar
If it suits your needs, then keep it. If you find a setup that you like better... get it. There is nothing wrong with what you have.
Modified by Tornadom at 8:04 AM 7/30/2006
Old Jul 28, 2006 | 03:24 AM
Fuster_Cluck's Avatar
I've heard bad things about APC. But if it's not broke (works for you), then I think you answered your own Q
Old Jul 28, 2006 | 07:51 AM
NycFox's Avatar
yeahhh man..i agree with everyone else..
untill it gives you real problems keep it
Old Jul 28, 2006 | 12:01 PM
Thanks guys, but to go with a less bouncy setup, what would u recommend?
Old Jul 28, 2006 | 12:57 PM
efvader's Avatar
Default Re: (Blacklabel182)
man you drive around hartford with that setup those roads are like kuwait city
look around and see whats out there, alot of people like the koni/gc setup..
or just ditch those apcs and get some decent springs
Old Jul 28, 2006 | 02:28 PM
Default Re: (efvader)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efvader &raquo;</TD></TR><TR><TD CLASS="quote">man you drive around hartford with that setup those roads are like kuwait city
or just ditch those apcs and get some decent springs </TD></TR></TABLE>
ya, i try to avoid actual city driving as much as possible, lol.
one of my struts is leaking oil, so i was gonna purchase a new setup (possibly upgrading to a coilover system?)
I was thinking KSports with a Tein EDFC?
Old Jul 29, 2006 | 10:48 PM
TunerN00b's Avatar
If you like your current spring rates, then keep them. No reason to change out if you like what you have. If its bouncy, then it sounds like you don't have enough shock for your springs. Get better shocks that can handle the spring rates you have (though AGX are adjustable and I hear many good things about them). If you've already blown one shock out, you're either way too low, or completely underdamped for your spring rates.
Old Jul 29, 2006 | 11:02 PM
FalkenSiR's Avatar
Lots of people confuse bouncyness with stiffness, have you tried softening your shocks? Have you checked for shock travel? have the shocks had the bump stops cut? I've seen bouncy rides due to non cut bump stops.
Old Jul 31, 2006 | 02:28 PM
:Andrew's Avatar
Default Re: Bad setup??? (fast95eg8)
good choice with the shocks bad choice on the coilovers
knowledge112
Jan 26, 2005 07:07 PM
