D16 wont start.. good spark, 40psi pressure at fuel filter IM STUMPED HELP!
Old Jul 27, 2006 | 01:11 PM
XLR8 GS-R's Avatar
Default D16 wont start.. good spark, 40psi pressure at fuel filter IM STUMPED HELP!
Hey my girlfriend was about a mile away from her house and was merging onto the highway when her car died. At the scene i tried starting it. It would stumble but never completely turn over....
I replaced cap rotor plugs and wires. Spark is great. I checked fuel pressure at the filter and got 40psi. When I turn over now it seems as it wants to start but only on 1 or 2 cylinders. When i open the throttle i get a small backfire in the intake manifold when trying to start.
Also i can hear a small hissing sound when i first try and crank it over. Almost sounds like leaking compression or something from a cylinder??? WHAT THE HELL COULD THE PROBLEM be? I hate looking a fool when my girl cant get to work in the past 2 days.
Old Jul 27, 2006 | 01:12 PM
XLR8 GS-R's Avatar
Default Re: D16 wont start.. good spark, 40psi pressure at fuel filter IM STUMPED HELP! (XLR8 GS-R)
also i forgot to say there has been a staeady coolant leak the past few months where i fill it up once a week or so. Maybe the car overheated? But i checked the plugs and no sign of too much heat
Old Jul 27, 2006 | 01:44 PM
Slopoke's Avatar
Do a compression and leak down test.
If you have fuel, spark, and air and it still wont start, you probably have a mechanical problem.
Old Jul 27, 2006 | 02:11 PM
XLR8 GS-R's Avatar
Default Re: D16 wont start.. good spark, 40psi pressure at fuel filter IM STUMPED HELP! (Slopoke)
Thanks slowpoke im gonna go over and do a compression test now- ill let u know
Old Jul 27, 2006 | 07:23 PM
XLR8 GS-R's Avatar
lil rain delay here in the pa im gonna do the comp test tommorow. If the headgasket was done for and thats where the coolant has been going- it would still run right? Its wierd when i crank it sounds like i can hear the compression leaking out on one of the cylinders. It has the sound when you turn a motor over without any intake / exhaust manifolds on. But just on one. ...Hope the test shows something this has been the longest time finding out a prob with a car
Old Jul 27, 2006 | 07:26 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XLR8 GS-R &raquo;</TD></TR><TR><TD CLASS="quote">also i forgot to say there has been a staeady coolant leak the past few months where i fill it up once a week or so. Maybe the car overheated? But i checked the plugs and no sign of too much heat </TD></TR></TABLE>
Combined with the "hissing sound" I'd say you did a number on your head gasket.
Old Jul 27, 2006 | 07:45 PM
commotion's Avatar
water will not compress remember that
Old Jul 27, 2006 | 08:15 PM
Unceasing Measure
Default Re: D16 wont start.. good spark, 40psi pressure at fuel filter IM STUMPED HELP! (commotion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by commotion &raquo;</TD></TR><TR><TD CLASS="quote">water will not compress as well as air remember that </TD></TR></TABLE>
Fixed that for you.
Old Jul 31, 2006 | 02:36 PM
XLR8 GS-R's Avatar
Default Re: D16 wont start.. good spark, 40psi pressure at fuel filter IM STUMPED HELP! (Archidictus)
Finally did a compression test . but i have no leakdown vac gauge so i can only work w/ wat i got
4321
1=45psi
2=25psi
3=35psi
4=32psi
HAAHHA OMG
these are lowest numbers i have ever seen. I am going to start taking the head off today. That head gasket must have seriously nuked. I bet it was the BARRS that helped blow it... Alot of carbon deposits were shooting up out of the spark holes, but i think that was because of the gas flooding/cleaning that i have been cranking it over the past few days when i was working on it.
Old Jul 31, 2006 | 04:22 PM
XLR8 GS-R's Avatar
So what do yall think???
Old Jul 31, 2006 | 05:23 PM
thehatchninja's Avatar
i think it's time to pull the head off.
jonnythan
26
Mar 26, 2017 07:52 AM
hayn_integra
Oct 23, 2007 10:09 AM
DSayavan
Jan 6, 2005 11:43 AM
Turbo-Honda
Jan 5, 2005 05:08 AM
92LudeSI
Jul 16, 2003 05:16 AM
