**HELP!! just put my d16a6 together, timing is right, still runs rough as hell!!!***
Old Jul 27, 2006 | 11:05 AM
hondasaurusrex's Avatar
Default **HELP!! just put my d16a6 together, timing is right, still runs rough as hell!!!***
i dont get it, my cam gear is dead nuts on, the crank is dead nuts on, and it still runs pretty rough...just put a new (new to me) head on it, and it needs to run good TONIGHT!!!! HEEEEELLLPPP!!!!!
any suggestions welcome......
Old Jul 27, 2006 | 11:46 AM
98lude-t's Avatar
Default Re: **HELP!! just put my d16a6 together, timing is right, still runs rough as hell!!!*** (hondasauru
check your valve clearaces if its to tight it will expletive things up
better loose than to tight
Old Jul 27, 2006 | 11:55 AM
Loserkidwac's Avatar
Did you line up the cam on the marks on the side or this mark:
The correct timing for the 90-91 a6 or maybe all of them is that red line and mark I circled
I never check valve clearance on that head so you should probably give it a good adjustment...but my motor ran pretty strong before my swap
Old Jul 27, 2006 | 12:16 PM
si90rex's Avatar
try new spark plugs ur probly just missing
Old Jul 27, 2006 | 12:39 PM
all the timing marks are lining up pretty good, and when i adjust the dist. it just dies...and i havent the slightest of clues how to check valve clearances...i've got the haynes manual and all...but valvetrain work is a little beyond me
Old Jul 27, 2006 | 12:41 PM
Old Jul 27, 2006 | 12:53 PM
Bump...Someone should have an idea what to check for here
Old Jul 27, 2006 | 06:08 PM
1990si's Avatar
dizzy problems maybe?
Old Jul 27, 2006 | 06:15 PM
Default Re: (1990si)
well, ive got it at least running now...but now the exhaust is blowin white smoke like cheech and chong are somewhere in my exhaust havin a big ole' time...brakes are failing for some stupid reason too...oil and coolant are both brand new, full, and clean as a whistle..i dono wtf is wrong with this damned thing...
any ideas??
Old Jul 27, 2006 | 06:24 PM
Default Re: (hondasaurusrex)
Dude Bad brake booster Your smoke is brake fluid getting sucked into the motor through the vac line
Justephen Sae
Feb 1, 2015 08:20 AM
Xscort
36
Jul 25, 2007 05:32 PM
Y2KCivicSiR
May 9, 2005 09:56 PM
HamiltonRex
Nov 14, 2004 02:04 PM
HXvtec
Mar 23, 2004 09:12 AM
