Need to double check!
Old Jul 27, 2006 | 07:20 AM
Civic Hybrid's Avatar
Default Need to double check!
Im trying to find a new transmission for my b16a. I could just buy a new b16 trans, but I was wondering if the CTR or ITR trans just bolts right up, just as easy as the stock b16 trans? Input would be helpful.
Old Jul 27, 2006 | 07:23 AM
philosofy1's Avatar
Default Re: Need to double check! (Civic Hybrid)
yes the ctr and itr bolt up. all b-series trannies bolt right up to any b-series motor. don't know how easy it is or beneficial for a ctr, but a itr , and a regular b16 is just as good.
Old Jul 27, 2006 | 07:31 AM
Default Re: Need to double check! (philosofy1)
So the ITR trans would be the better one.
Old Jul 27, 2006 | 07:36 AM
philosofy1's Avatar
the itr? of coarse, but it's the most expensive and quite hard to find, unless you order straight from the dealer. the b16 has the same gear ratio but no limited slip like the itr (unless it's the jem b16a, where they came w/an optional limite slip), if you can get a b16 for cheap then pick just the limited slip and install it you be set. don't know if it's all worth it if a shop does it. it might come out to being the same as just ordering a itr.
Old Jul 27, 2006 | 12:15 PM
I can only get my hands on a CTR b16 trans and im pretty sure they come with the limited slip already. Alrite well thanks for the help man.
Old Jul 27, 2006 | 12:27 PM
JDMlyfestyle's Avatar
IF you got the Chedda get the JDM ITR 4.7 FD LSD tranny. those are a little harder to comeby. but worth every cent
phaiwezzie
May 10, 2018 11:08 AM
justinwazner
Mar 7, 2011 10:19 AM
November
Nov 14, 2007 07:20 AM
wdelsolo
Sep 14, 2005 08:21 PM
theslugbug
10
Oct 27, 2003 03:30 PM
