b20 conversion
Old Jul 27, 2006 | 03:50 AM
jdm ek9 101's Avatar
Default b20 conversion
iv get a civic type r b16b and want to do a b20 bottom on it.can some one give me alist of all the parts i need.
can you give me the best size pistons and rods and will i need racing sleeves if iwant to rev to 9,000rpm
please need info fast i wana order the parts this week.
Old Jul 27, 2006 | 07:06 AM
Default Re: b20 conversion (tj CTR)
bump
Old Jul 29, 2006 | 08:34 AM
bump
Old Jul 29, 2006 | 12:17 PM
civicstar's Avatar
b20 blocks sleeves are weak from the start, after i think 7500 they sag anyways. its a good idea to get it sleeved. b20 pistons are 84mm and if your going to have this motor a high compression motor, go with either JE,arias, or CP(you can go over sized if you want, 84.5mm or 85 or 86). i think CP is the cheapest out of the 3. for the rods, go with the stock length b20 rods but get H Beam rods. and for this conversion, you are going to need a vtec oil line kit. and then a head gasket, and the LS/vtec dowel pins if you dont want to drill your head to fit the stock b20 pins. i cant remeber if you can just use your b16 dowel pins
Old Jul 29, 2006 | 01:26 PM
Default Re: b20 conversion (civicstar)
so i can use the b20 crank?? and just change the pistons an rods.will the b20 crank hold 9,500 rpm
Old Jul 29, 2006 | 03:36 PM
civicstar's Avatar
yeh it will hold i never heard of throwing a crank, but throwing a rod. usually at high reving it puts alot more stress on the rods and cyl walls. if you put a girdle on the bottom end, get good rods and have it sleeved, you can rev it all day that high. and make sure u have a good oil pump because at that RPM. the stock pump will give out very soon
Old Jul 29, 2006 | 04:24 PM
chargedek's Avatar
If you are going to rev to 9500 you will ned to get the standard crank balanced or like I done was get a crower billet crank
9200rpm daily baby
Old Jul 29, 2006 | 09:54 PM
civicstar's Avatar
Default Re: b20 conversion (chargedek)
yep i like the crower cranks myself but its alot cheaper to just balance it.
Old Jul 30, 2006 | 01:46 AM
ok so whats a good set of rods and pistons??and whats the best piston sizes.i just want a bullet proof b20vtec
Old Jul 30, 2006 | 11:46 AM
civicstar's Avatar
84mm is really reliable because its the stock size but i like to go either 84.5mm or 85. usually the aftermarket sleeves max out at 87.5mm. Aftermarket sleeves are even good enough to go 86mm and still be very reliable. Eagle rods are very recommendable rods. most people that have them would recommend them. as for pistons, go with either CP, ARIAS or JE. CP is the cheapest price but are still good. JE and ARIAS are alil bit more expensive but are really good pistons
Old Jul 31, 2006 | 08:28 AM
im going to fit racing sleeves aswell just to make sure.
j_the_guy
Dec 18, 2018 10:47 PM
omarej1
Dec 17, 2011 05:30 AM
ghost86
Jul 22, 2009 04:22 PM
badboiiricer6
Aug 5, 2008 09:39 AM
oianarchy
Feb 25, 2006 09:55 PM
