vibration on right side of car when under power
Old Jul 26, 2006 | 08:24 PM
projectek's Avatar
Default vibration on right side of car when under power
This is a two part question
1. I have a jdm b16a(2) with lsd trany in a 98 cx. When I am really gettin on the power the right side of car shakes. I have checked and rechecked all the bolts and mounts and they are ok. There is no play in the wheel bearing and the shafts that came with the swap look good. Now I have been told it may just be the LSD doing its job. It may be a bad cv shaft or my final drive had fallen out of place when the swap was done (although I have heard this is really rare and near impossible to happen, and i would think with out the final drive in place I would notice some problem in the shifting/revs)
2. what are average top mph in each gear on a b16 in an ek only mod for now is intake?
Old Jul 26, 2006 | 09:21 PM
dunkd's Avatar
axle
Old Jul 26, 2006 | 09:45 PM
tempsohc's Avatar
Default Re: (dunkd)
most likely it is the axle...you can check this by going into a left turn and put the car under load the right side axle and wheel will feel likes its vibrating and vice versa...my motor did this after installing a clutch and flywheel...idk....
Blue00Si
Suspension & Brakes
20
Jan 7, 2015 05:20 PM
GSR4U2NV
Oct 9, 2006 07:03 AM
projectek
Jul 17, 2006 03:46 PM
servion
Jul 1, 2003 11:59 AM
