starts on hot days
Old Jul 26, 2006 | 02:50 PM
upinsmoke's Avatar
Default starts on hot days
hey everyone , can anyone shed some light. On hot days my 91 accond has problems starting up right away, i ll turn the key and it turns over but won't catch, so what i have to do is wait 10 mins then it will start with no problems, only on hot days. Why is that?
Old Jul 26, 2006 | 05:50 PM
philadd's Avatar
Default Re: starts on hot days (upinsmoke)
Main relay.
Main relay location.
How to fix it.
Old Jul 27, 2006 | 05:45 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: starts on hot days (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">Main relay.
How to fix it.</TD></TR></TABLE>
Yup. Preludes of the same years had the exact same problem
Old Jul 27, 2006 | 09:17 AM
flight50's Avatar
Default Re: starts on hot days (213374U)
yeah more than likely its the relay. had mine resolider a year ago and hasn't do it again since then. the honda shop that did it for me said its better to just resolider it because putting on a new one will do the same after a while and it cost more. solider was cheaper.
Old Jul 27, 2006 | 09:02 PM
cats_on_ice's Avatar
Default Re: starts on hot days (flight50)
I took mine out, after experiencing the same symptoms you describe.
There were only two obviously broken (cracked around the bottom) connections, but 90% of the connections were super skimpy on the solder, and generally looked bad...cheap factory manufacturing...so I stripped and re-soldered ALL of the connections. Just because I could.
If you can, do it yourself. Replacing it is, very probably, a total waste of money. And paying someone to solder would really suck. Hope you have soldering tools.
ninjagaiden
13
Jul 6, 2007 03:44 PM
kittieeve
Jun 1, 2006 02:31 PM
triple_s1x
Feb 27, 2005 11:10 AM
wilrock
Oct 18, 2004 08:44 PM
dirtyrotten
Jun 22, 2004 03:08 PM
