92-96 header for b16?
Old Jul 26, 2006 | 01:03 PM
1_slow_crx's Avatar
Default 94-97 del sol header for b16?
is the 94-97 del sol vtech not a b16a? with two o2 sensors?
Modified by 1_slow_crx at 4:01 PM 7/26/2006
Old Jul 26, 2006 | 01:26 PM
EL Vap133's Avatar
Default Re: 92-96 header for b16? (1_slow_crx)
99-00 Civic Si, but just tell them it is for a B16a and they should know what to get you.
Old Jul 26, 2006 | 01:44 PM
1_slow_crx's Avatar
Default Re: 92-96 header for b16? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">99-00 Civic Si, but just tell them it is for a B16a and they should know what to get you. </TD></TR></TABLE>
so, there is not clearence issue with 99 civic si one?
my car is obd0 so should i just weld a bung to it?
Old Jul 26, 2006 | 02:08 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1_slow_crx &raquo;</TD></TR><TR><TD CLASS="quote">
my car is obd0 so should i just weld a bung to it? </TD></TR></TABLE>
As far as it hangs, there might but that depends on a few factors. What mount kit you're using, how low the car is, etc.
Yes, have the extra bung welded onto it unless you want to buy the Hasport header which is a direct fit.
Old Jul 26, 2006 | 02:26 PM
1_slow_crx's Avatar
Yes, have the extra bung welded onto it unless you want to buy the Hasport header which is a direct fit. </TD></TR></TABLE>
im not sure what mounts it is, but im on sttock ride height right now.. but will be on coils soon. is there a header that isnt as low to ground?
Old Jul 26, 2006 | 02:45 PM
1_slow_crx's Avatar
Old Jul 26, 2006 | 03:37 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1_slow_crx &raquo;</TD></TR><TR><TD CLASS="quote">is the 94-97 del sol vtech not a b16a? with two o2 sensors?</TD></TR></TABLE>
The '94-95 del Sol VTEC used a B16A3 which was OBD-1 and had one oxygen sensor which plugged into the catalytic convertor.
The '96-97 del Sol VTEC used a B16A2 which was OBD-2a and had two oxygen sensors - one that plugged into the A-pipe (bottom half of header) just before the cat, and one that plugged into the cat.
Old Jul 26, 2006 | 04:49 PM
1_slow_crx's Avatar
Default Re: 92-96 header for b16? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
The '96-97 del Sol VTEC used a B16A2 which was OBD-2a and had two oxygen sensors - one that plugged into the A-pipe (bottom half of header) just before the cat, and one that plugged into the cat.</TD></TR></TABLE>
i have a b16a1?vwith two o2's...
would the 96-97 work for me?
Old Jul 26, 2006 | 05:06 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1_slow_crx &raquo;</TD></TR><TR><TD CLASS="quote">i have a b16a1?vwith two o2's...
would the 96-97 work for me?</TD></TR></TABLE>
IIRC, pre-OBD oxygen sensors use a single wire. OBD-2 sensors are heated and use 4 wires.
Old Jul 26, 2006 | 05:50 PM
1_slow_crx's Avatar
so what header would be best for my car.. say a DC sport, but from what car?
Old Jul 27, 2006 | 12:30 AM
1_slow_crx's Avatar
IIRC, pre-OBD oxygen sensors use a single wire. OBD-2 sensors are heated and use 4 wires.</TD></TR></TABLE>
but does that matter?
the o2 hole will still be same size . will it work on a b16a1?
Old Jul 27, 2006 | 07:07 AM
1_slow_crx's Avatar
Default Re: 94-97 del sol header for b16? (1_slow_crx)
Old Jul 27, 2006 | 10:36 PM
Targa250R's Avatar
be professional
Sorry, I thought you were asking about the O2 sensors rather than the header.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1_slow_crx &raquo;</TD></TR><TR><TD CLASS="quote">so what header would be best for my car.. say a DC sport, but from what car? </TD></TR></TABLE>
'96-97 del Sol VTEC or '99-00 Civic Si.
Old Jul 28, 2006 | 03:07 AM
Moto-hashiriya's Avatar
or any JDM header that was made for the EF8/9 SiR. Fujitsubo, etc
the_wrath_of_Khan
Jul 31, 2008 01:24 AM
whiteb16
Sep 12, 2006 03:38 PM
m0use
Jul 19, 2006 01:27 PM
slikflip
Jul 13, 2006 03:04 PM
jdmspeck
Feb 5, 2005 12:46 AM
