****94-97 DELSOL B16A MOTOR INTO 99-00 CIVIC EX...HELP!!!!********
IM IN THE PROCESS OF SWAPPING MY 0BD1 B16A IN TO MY 99 CIVIC. I JUST NEED TO KNOW IF IT WILL BE AN EASY SWAP, JUST LIKE AN OBD2 B16A IN TO MY CAR. DO I NEED ANYTHING ELSE BEFORE I DROP IT IN???WHAT JUMPER WIRING HARNESS SHOULD I GET?? AND WILL THE SAME TRANNY OFF THE B16 WORK ON MY CAR???
THANKS!
THANKS!
Re: ****94-97 DELSOL B16A MOTOR INTO 99-00 CIVIC EX...HELP!!!!******** (slikflip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slikflip »</TD></TR><TR><TD CLASS="quote">IM IN THE PROCESS OF SWAPPING MY 0BD1 B16A IN TO MY 99 CIVIC. I JUST NEED TO KNOW IF IT WILL BE AN EASY SWAP, JUST LIKE AN OBD2 B16A IN TO MY CAR. DO I NEED ANYTHING ELSE BEFORE I DROP IT IN???WHAT JUMPER WIRING HARNESS SHOULD I GET?? AND WILL THE SAME TRANNY OFF THE B16 WORK ON MY CAR???
THANKS!</TD></TR></TABLE>
STOP USING ******* CAPLOCKS ON BOTH YOUR POST!
and SEARCH
and SEARCH
Re: ****94-97 DELSOL B16A MOTOR INTO 99-00 CIVIC EX...HELP!!!!******** (G2 Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed »</TD></TR><TR><TD CLASS="quote">
and SEARCH</TD></TR></TABLE>
yeah that helps!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slikflip »</TD></TR><TR><TD CLASS="quote">IM IN THE PROCESS OF SWAPPING MY 0BD1 B16A IN TO MY 99 CIVIC. I JUST NEED TO KNOW IF IT WILL BE AN EASY SWAP, JUST LIKE AN OBD2 B16A IN TO MY CAR. DO I NEED ANYTHING ELSE BEFORE I DROP IT IN???WHAT JUMPER WIRING HARNESS SHOULD I GET?? AND WILL THE SAME TRANNY OFF THE B16 WORK ON MY CAR???
the swap should be cake. yes the tranny will work. get the hasport wire conversions for the obd1/obd2 transition. it will make the swap 10x easier.
get an obd2 B series dizzy, injectors, and alternator. and most importantly and 99-00 si wiring harnes, if its an ex you can use that same wirng harness but its way easier with an SI harness
