cel help when changing ecu's
ok, so im running a mini-me with a 16a6 block and Y8 head. Im currently running with a pm6 and engine light comes on with code 7. when i switch to a PR4 ecu, theres no engine light. is it safe to just run the pr4? for now?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
check TPS make sure its working
green/white = ground
yel/wht i think = changing voltage based on thrtottle
red/blu = 5v
check to make sure green/white and red/blue are working. if you ned ecu diagram tell me and then you can pull the ecu plug and check if its going through. also check the pins on the ecu maybe the ecu pin fell off...? and your throwing just the code on that. if you arnt throwing TPS with the other ecu you are probably fine
edit: corrected my self on wrong wires, info shoudl be right now :D
red/blu = 5v
