4-1 header with cat ?
Old Jul 26, 2006 | 11:48 AM
xelloss's Avatar
Default 4-1 header with cat ?
Does anyone knows that if I change the header, can I still use a cat? I'm having a 96 civic 4 doors (D16Y7 engine). The stock cat is just under the hood, in front of the engine, not under the car, if I change the header, there seem not enough space to put a cat after the header.....Please help....
Old Jul 26, 2006 | 11:50 AM
sicones's Avatar
Default Re: 4-1 header with cat ? (xelloss)
you need a 96-00 EX cat, this has been covered a bizzilllion times
Sleepy_Red_hatch's Avatar
you're going to have to modify your exhaust system and bolt the exhaust manifold to a cat from any normal honda that didnt have the cat-on-manifold system (i think CX/VX where the only ones to use this) and then modify you're exhaust system to fit the extra lenght, a muffler shop should be able to do it relatively cheap and a used honda cat is decently priced in the marketplace, goodluck.
Old Jul 26, 2006 | 12:07 PM
xelloss's Avatar
Default Re: 4-1 header with cat ? (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">you're going to have to modify your exhaust system and bolt the exhaust manifold to a cat from any normal honda that didnt have the cat-on-manifold system (i think CX/VX where the only ones to use this) and then modify you're exhaust system to fit the extra lenght, a muffler shop should be able to do it relatively cheap and a used honda cat is decently priced in the marketplace, goodluck.</TD></TR></TABLE>
I've already have modified the whole cat back exhaust...
Not quite sure what is cat-on-manifold system, any link?
EFstyle
Jun 18, 2006 05:21 PM
ekx4
May 19, 2006 09:05 AM
kornerk12
Apr 23, 2006 04:32 PM
Jimmy
Jul 24, 2003 08:20 PM
Kasper.
12
Jul 8, 2002 05:38 PM
