lost C-clip on rear quarter window
I'm sure you all have done this before when taking off that rear quarter window. Last night i was bondo-ing some spots i had ground rust out of earlier that day and i had to take off the window, so i took off that little c-clip that kinda holds on the window to the window opener latch. I have an 89 civic si and now i'm kinda pissed cause i have to leave my car in the garage becuase i'm afraid the window will break off as soon as i hit a bump.
Please help if you know where I could get anohter one. I looked on majestic honda but i couldnt see what number it was, it's all faded.
Go to local home improvement store and ask for E-clips in hardware. I had to buy a few when I took the window out and lost the clip behind the panel where the seat belt goes in. When its really hot outside and I am taking a long ride I'll take both the rears out to get more air flow because of the lack of A/C. Just Dont over-tighten the screws when you put the windows back in because the plastic clip inside will crack.
just for reference, since majestic honda's diagrams SUCK, use slhondaparts.com. The diagrams there are exactly the same, and they are clear as can be. They also provide real honda part numbers. Use majestic honda for the number reference though, because slhondaparts doesn't provide the numbers (why??). Its a pain, but it works.
so your part you were looking for is:
87480 031 2 E-RING (7MM) NO COLOR 1.94 1.45
pityocamptes
Apr 21, 2011 03:53 PM
RBaluca.com
Aug 20, 2006 02:08 PM
samson1
Jun 21, 2004 08:35 AM
