can't adjust ground control
Old Jul 26, 2006 | 09:18 AM
intgraCA's Avatar
Default can't adjust ground control
its been a long time since i installed my gc....was there a tool to turn the ground control ring up and down? i tried turning it up and down with my hand but it dind't move. please help. thanks
Old Jul 26, 2006 | 09:44 AM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: can't adjust ground control (intgraCA)
Nope, lossen the set screw alot and just turn by hand. Make sure the wheels are off and car is on jack stands. Worked for me about a month ago.
Old Jul 26, 2006 | 09:47 AM
5 Speed AP2's Avatar
Mines would sometimes get stuck in place cause of dirt and ****, and i'd have to remove that screw entirely, use a flat head to open it up a bit and gorilla force that sucker to move.
Old Jul 26, 2006 | 12:36 PM
importdude2000's Avatar
tein wrench works wonders
u need a spanner wrench
Old Jul 26, 2006 | 01:12 PM
-Todd-'s Avatar
Default Re: can't adjust ground control (5 Speed DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5 Speed DC2 &raquo;</TD></TR><TR><TD CLASS="quote">Mines would sometimes get stuck in place cause of dirt and ****, and i'd have to remove that screw entirely, use a flat head to open it up a bit and gorilla force that sucker to move.
Mine used to do that, it was a bitch. Luckily I found a coilover wrech tool that came with some cheap coilovers I bought a long time ago.
Old Jul 26, 2006 | 01:40 PM
96 GSR-T's Avatar
Default Re: can't adjust ground control (-Todd-)
I had to use 2 pipe wrenches on mine recently, WD40 and alot of patience. I have had them for like 5yrs now and never adjusted the ride height.
Old Jul 26, 2006 | 08:11 PM
jared99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Todd- &raquo;</TD></TR><TR><TD CLASS="quote">
Mine used to do that, it was a bitch. Luckily I found a coilover wrech tool that came with some cheap coilovers I bought a long time ago. </TD></TR></TABLE>
I actually have a pair of these if you want them.
Old Jul 26, 2006 | 08:24 PM
96 GSR-T's Avatar
Default Re: can't adjust ground control (jared99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jared99 &raquo;</TD></TR><TR><TD CLASS="quote">
I actually have a pair of these if you want them. </TD></TR></TABLE>
How much are they new? I would love to get a set.
Old Jul 27, 2006 | 12:40 AM
90runner157's Avatar
Default Re: can't adjust ground control (96 GSR-T)
if its been years you got mad dirt in the threads with most likly a lil surface rust. use some penitrating oil and maybe try to blow it with comp air if its available.
Old Jul 27, 2006 | 04:38 AM
jared99's Avatar
I don't know...they just came with a set of cheap coilovers I bought a long time ago. I ditched the coilovers and kept the wrenches.
Old Jul 27, 2006 | 08:55 AM
db8gsr_teg's Avatar
my ground control uses a hex key. Just lossen it and and turn it.
B19CivicHB
Jul 3, 2009 07:49 PM
fenominal
Nov 7, 2007 08:05 AM
Topher.
Suspension & Brakes
17
Jul 19, 2007 01:58 PM
TheNasty0ne
40
Sep 1, 2005 12:49 AM
Integra187
Jan 13, 2005 08:07 AM
