Fuel delivery for f.i. ??'s
Does anyone know what the horse power limit of the factory fuel lines is, using a walbro 255 lph fuel pump? And what is the biggest injectors will the factory lines support? I just want to know where i'm going to have to up grade the lines and get a aeromotive pump. This will help me decide what size turbo i need to get either way.
Thanks
Thanks
stock lines typically can make up to 500-600 hp on a b-series with 1000cc injectors with a in tank walbro...People wanting to make higher usually max out their fuel pumps then anything else...this is where you need to upgrade ur lines and fuel pump...i would go with the bosch fuel pump..talk to stan...
iBrandon
Feb 17, 2005 02:33 PM
EF_LSVtec
Oct 7, 2002 11:18 AM
