B20 with B16 tranny shift linkage question
ok so im running a B20 with a B16 tranny and the linkage im using right now is from a 94 LS, and it wont let me go into 5th gear or reverse, ive also tried a B16 linkage and it does the same thing, i also noticed that the shifter sits way too akward, it sits way up left, it looks as if it was in first gear... so my question is what linkage do i use? or is it the tranny that wont let me go into 5th or Reverse gear?
both shift linkages will work unless both are bent or something
try bleeding the clutch again assuming you did already
oh and what car is it in and what clutch fw are you using
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBEengineering »</TD></TR><TR><TD CLASS="quote">both shift linkages will work unless both are bent or something
oh and what car is it in and what clutch fw are you using</TD></TR></TABLE>
the flywheels is from an LS and the clutch is stock B16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBEengineering »</TD></TR><TR><TD CLASS="quote">its one of those i couldnt tell with out looking at things
oh and how do you guys pass ref with b20s in hatches out there</TD></TR></TABLE>
you dont.
unless you know someone.
you dont.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knockout »</TD></TR><TR><TD CLASS="quote">
you dont.
lol
you dont.
</TD></TR></TABLE>lol
Unless you managed to get a Del Sol shift linkage some how, there should not be an issue with your set up. Any of the Integra or 99-00 Civic Si linkages should work with no problems. You need to be looking at the transmission, release bearing, release fork and stuff like that if 5th and reverse are not avaliable.
89civichatchback
13
Jul 9, 2003 11:23 AM
