Need some help with O2 sensor and these plugs:B16 CRX
Old Jul 25, 2006 | 10:02 PM
Trevor's Avatar
Default Need some help with O2 sensor and these plugs:B16 CRX
Ok I have searched and I know the O2 sensor has been discussed alot here.
I just cant find a clear answer.
The car is an 88 CRX DX. Hasport harness with a PR3 ECU chipped by Katman at Jdmhondaparts.
I have these two plugs that I think go to the O2 sensors. I also am not sure if the chip in my ECU is for one or two O2 Sensors. I have a DC header with a bung, and a bung in the exhaust after the header.
Should I run one or two?
Are these plugs both to the O2 sensors.
Thanks for any help.
Old Jul 26, 2006 | 10:49 AM
Trevor's Avatar
Default Re: Need some help with O2 sensor and these plugs:B16 CRX (Trevor)
anyone?
Old Jul 27, 2006 | 04:54 AM
Trevor's Avatar
Old Jul 27, 2006 | 06:05 AM
mzaner's Avatar
I have the same wires on my car. I know for a fact that the clear/yellow one is for a single wire o2 sensor. I don't know what the green one connects to, maybe somebody else knows about this one, but I'm pretty sure it's an o2 sensor as well, another single wire one.
Old Jul 27, 2006 | 08:05 AM
mzaner's Avatar
Default Re: Need some help with O2 sensor and these plugs:B16 CRX (mzaner)
obd-0 B16A's need 2 o2 sensors, one reads pistons 1 and 4 and the other reads pistons 2 and 3.
Modified by mzaner at 12:33 PM 7/27/2006
Old Jul 27, 2006 | 08:19 AM
crx_88_si's Avatar
Old Jul 27, 2006 | 08:28 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (crx_88_si)
thanks crx_88_si,
A picture is worth a thousand words.
Old Jul 27, 2006 | 09:39 AM
BoostedEF's Avatar
Default Re: (mar778c)
Not to jack but
Primary would be 1 & 4 ? C16 ?
Secondary would be 2 & 3 ? C8 ?
Old Jan 7, 2007 | 06:33 PM
ill_will626's Avatar
when i go to the parts store to get THE O2 SENSOR what am i going to look for TO GET?
Old Jan 7, 2007 | 06:58 PM
Crx Jimmy's Avatar
Default Re: (ill_will626)
just ask for one for your car, any 1 wire will work, the stock civic/crx ones work fine
beerguy6903
Mar 6, 2009 04:23 PM
Blanket Jackson
Apr 30, 2004 09:34 AM
Ruby Civic
Jun 15, 2003 05:57 PM
gtpilot
Dec 12, 2002 12:27 PM
boostinb18
Jul 26, 2002 01:31 PM
