o2 sensor in a 88 crx
I have an 88 crx si, I put a b16 trubo in it. The crx si only has 1 o2 sensor wire, the b16 obd1 has 2 o2 sensors. I am going to run the wires so I am using only 1 o2 sensor. Timmay, from Idaho said he knows how to do it but he not been able to help me please if you have any info on how to do it.
Modified by HONDAofPOKY at 6:41 PM 4/28/2004
what you need to do is A. get a chipped ecu.. or B find the wiring diagram to convert to 1 o2... This is done by i think connecting both o2 wires.. to the same o2.. not sure... search will help... .. I would chip the ecu and disable that second o2 plus get some more power out of the ecu ... at the same time
beerguy6903
Mar 6, 2009 04:23 PM
Trevor
Jan 7, 2007 06:58 PM
