problem with idle,.....
Several possible problems...most common are:
FITV Needs to be tightened.
IACV Needs to be cleaned.
Vacuum leak around TB/intake manifold.
Possible air bubbles in the coolent system.
Make sure there's no vacuum leaks...then check the FITV, IACV. FITV is probably your problem as it was on mine and seems to be the norm with it coming loose.
Read this thread for FITV (Fast Idle Thermo Valve)
https://honda-tech.com/zerothread?id=699787
This one for the IACV (Idle Air Control Valve)
http://www.g2ic.com/forums/sho...=iacv
already finished cleaning the FITV and the IACV, and my engine idles fine now,another problem, when i hit the accelerator....it stays at 1,500 and after a 6 to 8 second...it will drop back again to 850 or 900.....why it takes that long for the idle to go back??help
