Questions: Port and polish + removing valve seat
Old Jul 25, 2006 | 08:59 PM
Fallen86's Avatar
Default Questions: Port and polish + removing valve seat
Question 1: When port and polishing, the first step removing material, do i mostly open up the port openings only? or do i go in with my bit and remove material to enlarge the inside of the bit too? might be a dumb question but be nice if someone can tell me.
Question 2: How do i remove Valve Seats?? Is there a special tool i have to use?
Thanks guys, i searched but it seems that most people dont remove their valve seats... but i need to so i can do the port work.
Old Jul 26, 2006 | 11:15 AM
mmuller's Avatar
Mad Scientist
Default Re: Questions: Port and polish + removing valve seat (Fallen86)
i dont see why you want to take your valve seats off... since you have to match the throats and racks with them on.. if you port and then get the seat put in, then the matching will be off again.
you start by improving on casting flaws and finish. Unless radical dont enlarge the intake ports.
you can really mess things up if you dont know what your doing
Old Jul 26, 2006 | 12:05 PM
b18sihatch's Avatar
wouldnt recomned port and polish unless you are famillure with it, you could hurt the flow of the head if not done correctly, but you should be fine if just cleaning it up and making the casting flaws smoothe and all that
if you are working with a dremmel grinder i recomend finishing the ports with a adbrasive buff ball from dremmel. it will take all the rough surface you get from opening the port and smoothe it out....
Old Jul 26, 2006 | 12:47 PM
Fallen86's Avatar
Default Re: Questions: Port and polish + removing valve seat (b18sihatch)
its just that right now when i'm polishing the ports the little valve guide sticks down and gets in the way ,i think i called it the wrong thing...do you guys know what i'm talking about? or i can take a pic.
Old Jul 26, 2006 | 01:01 PM
b18sihatch's Avatar
valve guide? take a picture of your progress i wanna see
Old Jul 26, 2006 | 02:03 PM
Fallen86's Avatar
Alright here are the pics. i marked what i was talkin about with the arrows thanks for the help mang
i Keep Hitting Those when I'm grinding and polishing Cuz It Protrudes Down Into The Ports
Since We're on this subject i wanna ask 2 more questions with this next pic
1.Where the green arrow is,i'm supposed to make that edge nice and "unsharp" right?
2.And Know i'm Not Supposed To Touch Where the valve seat is, but Should I Start Polishing From Where the red arrow is? or further back?
Thanks Again guys
Old Jul 28, 2006 | 03:29 PM
Fallen86's Avatar
Old Jul 30, 2006 | 08:14 AM
.RTErnie's Avatar
you can grind on your guide, dont grind on your seat...dont polish on your seat. You have your machine shop grind a valve to sit flush when you polish your CC. But be VERY careful when you get close to the seat. I've taken out the guide down flush with the port with no problems whatsoever (non-honda app) If its your first time I wouldn't take a lot of material out... mostly polish. And make sure every port is the same...its easier if you do one small section of the each port then move on...not one port ...then the next. etc. good luck
Old Jul 30, 2006 | 10:18 AM
Fallen86's Avatar
Default Re: Questions: Port and polish + removing valve seat (Eric@HorsepowerFreaks)
ok that's what i thought. thanks man
Old Jul 30, 2006 | 10:32 AM
.RTErnie's Avatar
no problem! A good place to get porting tools is from http://www.mondello.com Tell Gentle Joe that the Eric the guy who continually looses the mandrels for sanding cartridges sent you lol. he got pretty upset that I lost the last three he sent me...lol i was like...they were all still taped together!
Old Jul 30, 2006 | 10:46 AM
Fallen86's Avatar
haha i was gonna ask for someting like that, the regula tools store like home depot doesnt carry everything that i need. especially those pointed sanding drums
Old Oct 13, 2006 | 09:19 AM
( o )( o )'s Avatar
back from the dead:
how do you remove the valve seats?
reason, the casting is shot - I figure all I can do with it is recycle the aluminum...but it has to be completely bare before they will take it.
Old Oct 14, 2006 | 05:24 AM
mmuller's Avatar
Mad Scientist
Default Re: Questions: Port and polish + removing valve seat (( o )( o ))
some people use a welder to contract the seat and make it pop out
Old Oct 15, 2006 | 09:33 AM
Duane_in_Japan's Avatar
Default Re: Questions: Port and polish + removing valve seat (mmuller)
I get about $30 for a recycled head here.
8OOSTED
Aug 12, 2009 09:22 PM
tegman23
May 31, 2009 06:47 PM
b20vtech
56
Nov 14, 2008 08:08 AM
turbodohcsi
Aug 7, 2006 08:09 AM
Vadian
Jul 21, 2003 02:09 PM
