Suspension rattle...yes i searched
Ok, on my 93 EX sedan, it has the wierdest rattle ever. When i drive on rough road or up my gravel drive...its rattles constantly from the drivers side. This rattle goes away when i have the brake pedal depressed. Any ideas? Its starting to **** me off.
And, im tired so my description may be a little vague
ive actually looked...and the only thing i can come too is this
the center of the brake caliper...the section that holds the pads is loose. Meaning i can pull it back and forth and make a similar rattle.
I was told this play was normal, but none of the other calipers have the looseness to them. Which led me to believe otherwise but i wanted to ask and make sure.
Maybe your upper ball joint. Do you hear a clunking while going over speed bumps? Grab the steering knuckle above the wheel and pull back and forth and see if it moves relative to the upper control arm. Or while it's on jackstands, lift the wheel up and down and look for the same movement.
yea dood that happends to me too. like when you drive over tought road and **** it rattles and ****. idk if its my suspension but yea hit me bacC when you find out what the solution is to this problem k? thans dood...
Dee
Dee
hey wats up dood... um yea i have that suspension thing too like when i go on rought roads and **** my car starts rattling and ****. do you know what the solution to the problem is? hit me bacC iight? thanks...
Dee
Dee
Make sure all of your bolts are tightened down on your shock tower. Check the top and bottom. I had a friend with this problem after we put is suspension on. It did that for a few days before we looked at it. The bolts at the top of the shock tower were coming loose. Tightened them down and no more ratteling.
bnuk013
Feb 8, 2008 02:23 PM
hondaless
Dec 19, 2005 12:31 PM
rice_classic
May 23, 2004 11:59 AM
E-Rok
Jan 18, 2004 03:51 PM
Spade
Jun 20, 2002 07:43 AM
