B18c1 obd1 in 99 ex
Old Jul 25, 2006 | 07:27 PM
HUYNH's Avatar
Default B18c1 obd1 in 99 ex
YO i got a big problem i finished swapping the gsr into my civic with a chipped p28 , right when i start it up it doesnt stay started unless i keep my foot on the gas, and when reved up to about 1.5-2k rpm the engine sputters like theres not enough gas or there is a misfire but reved passed that and its fine. any one have any idea what this could be??? i'd really appreciate some feedback thanks.
Old Jul 25, 2006 | 07:58 PM
HUYNH's Avatar
Default Re: B18c1 obd1 in 99 ex (HUYNH)
no one??
Old Jul 25, 2006 | 08:02 PM
Richie B's Avatar
you could check your vacuum lines, my car wouldn't idle for **** and that was the problem...
Old Jul 25, 2006 | 08:26 PM
HUYNH's Avatar
thanks bro
Old Jul 25, 2006 | 08:39 PM
Syndacate's Avatar
Check the IACV, and if u got a wideband check ur A/F ratio, if u got a FP guage, check ur fuel pressure as well...though it wouldn't make sense that it's not getting fuel if it's revving up fine...so it's probably the IACV (needs to be cleaned/changed) or the vacuum system is off (has a leak in it, sucking from some other place other than the intake...)
THere's a way to test the vacuum system for leaks, forgot how...do a search on that I guess...as for the IACV, cleaning it every now and then is good anyways IMO
If the vacuum system is completely sealed and the IACV is sealed & not clogged I would take another look at the ECU, make sure it's set up to immitate the P72... on the P72's stock fuel map
Old Jul 25, 2006 | 08:58 PM
HUYNH's Avatar
yeah thats what i heard but also people have been telling me it might also be the coil in the distributor?? thanks for the help
Old Jul 25, 2006 | 09:22 PM
HUYNH's Avatar
bump
Old Jul 26, 2006 | 08:34 PM
HUYNH's Avatar
any more input anyone??? please help
Old Jul 26, 2006 | 09:46 PM
Syndacate's Avatar
ya
It's not the dizzy...UNLESS, it's givin u breakup under acceleration, then it's possible, but a fucked up dizy won't ONLY give u problems at idle....it'll give ya breakup problems all 'round
Old Jul 26, 2006 | 10:02 PM
HUYNH's Avatar
yeah thats what im thinking hmmm would it be the ecu? because the guy i bought it from said it was chipt but if it wasnt would it still sputter at 1.5-2k rmps?
Old Jul 26, 2006 | 10:33 PM
9secondcivic's Avatar
whats up my name is ANDY i wanted to know how to post questions on here and how to sell some parts i got .. if you could let me know how to do this i dont know how to post or talk to people this is my first time doing this **** .... thank you
Old Jul 26, 2006 | 10:37 PM
hey also want check engine light is your car throwing? it could be the idol air control valve it probablyreading wrong or it no good
Old Jul 26, 2006 | 10:42 PM
HUYNH's Avatar
im not sure cause its p28 and the car is obd2 i dont know if i can get it checked with scanner
car_mo_na_po
Sep 11, 2011 07:04 PM
TRIGA
Dec 2, 2009 05:49 PM
1989CivicSi
Jun 4, 2006 08:12 PM
99hcguy
Jul 18, 2005 07:09 PM
EM1Guru
10
Oct 28, 2003 01:15 PM
