tyc headlights
Old Jul 25, 2006 | 04:02 PM
clemsonteg's Avatar
Default tyc headlights
my roomate wants to get a set of tyc projector headlights and hids for his 99 civic, but in this pic it looks like there is a place for 3 different bulbs and im pretty sure he only has 2, i keep telling him its probably not a good idea, does anyone have any expierience and is there actually 3 different bulbs there?
Old Jul 25, 2006 | 04:08 PM
Padawan's Avatar
Darth ModerVader
Default Re: tyc headlights (clemsonteg)
As far as a bolt-on HID option, these are probably a decent choice. The need for the extra bulb is due to the fact that the stock headlights use a dual-filament high/low beam.
Old Jul 25, 2006 | 04:19 PM
clemsonteg's Avatar
Default Re: tyc headlights (Padawan)
so this would split the regular dual beam into 2 single beams, and if he got a hi/low set of hid's there would be no use for the spot on the otherside of the projector?
Old Jul 25, 2006 | 04:47 PM
Padawan's Avatar
Darth ModerVader
I confused these lights with the housings that TYC offers for the '92-'95 Civics, which are DOT-approved HID units. The ones you showed here are just halogen housings. If your friend wants to install an HID setup in these, I would suggest retrofitting some OEM HID projectors into them (these can be found at places such as HID Planet. If he buys a high/low H4 HID kit, it simply won't fit in these housings.
Old Jul 25, 2006 | 05:17 PM
clemsonteg's Avatar
i did some research on them, hes got no computer where hes at right now so im doing it for him, these projectors split the regular dual filament into the 2 seen, an h1 and an h3 instead of the stock single h4, so he would have to go with an h1 kit and have an h3 high beam
Old Jul 25, 2006 | 06:14 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clemsonteg &raquo;</TD></TR><TR><TD CLASS="quote">i did some research on them, hes got no computer where hes at right now so im doing it for him, these projectors split the regular dual filament into the 2 seen, an h1 and an h3 instead of the stock single h4, so he would have to go with an h1 kit and have an h3 high beam</TD></TR></TABLE>
Correct. Not ideal, but better than an H4 kit in the stock housings.
turboman
Lighting
11
Jul 14, 2008 08:07 AM
NitroStickers
Sep 15, 2005 06:59 AM
ChaseIntegra
Jan 19, 2005 05:19 AM
96civicB20
Nov 3, 2003 05:06 PM
92SiB18C1
Nov 6, 2002 01:04 PM
