act clutch kit making noise
Old Jul 25, 2006 | 07:05 AM
1rude2l's Avatar
Default act clutch kit making noise
i got a b16 with type r tranny in my ek, installed a new 8.8 lb flywheel and act 4 puck race disk and pressure plate with the act kit (throwout bearing, pilot bearing)
issue im having it noise when the clutch is released (foot not on pedal) almost sounds like a rod knock its real loud, its not a rod knock and dosn't sound like the throwout bearing that makes kinda a grinding noise but this is a knocking noise almost identical to a rod knock, anyone else experience this or should i start to worry been driving like this for like 2000 miles no problems what so ever clutch grabs 4th and 5th if i want it to thanks for any input or ideas i know everyone gonna say flywheel bolts those was torqued and locktited everything was torqued incuding the pressure plate also noise goes away when you press the clutch in
Old Jul 25, 2006 | 08:53 AM
CardDealer's Avatar
Banned
Default Re: act clutch kit making noise (1rude2l)
Modified by CardDealer at 9:32 AM 11/16/2006
Old Jul 25, 2006 | 09:39 AM
birds_sol_94's Avatar
Default Re: act clutch kit making noise (schlit)
well i know this is kinda off the wall but me and abuddy put a exedy stage to clutch in a 98 mustang gt... sounds like the similar noise he was having after the installation.. we did the pressure plate, clutch, and lightened flywheel... first me thought it was the throwout bearings... wasnt it thought it was the flywheel.. wasnt it.. even had it sent back to exedy and balanced... thought it was the tranny put a new tranny in it... wasnt it... rebuilt the rear-end.. wasnt it... come to find out.. it was the clutch making the grinding noise... but it would only do it at certain rpms.. i dont know if that would apply to a honda... or not.. sounds like a the similar problem.. was it making the noise before the install..?? b/c if it wasnt.. i would check the clutch...
Old Jul 25, 2006 | 01:59 PM
1rude2l's Avatar
didnt make a noise with the stock clutch so the input bearing shouldn't be bad, the noise changes with rpm changes going down the road you don't hear it....at idle you can hear it just might ride on it and see what happens. i mean it performs very well just the noise of like a knocking sound like somethings flying around or something but if something was loose the centrifigual force of spinning around that fast should hold whatever still i would guess... has me boggled
Old Jul 28, 2006 | 02:17 PM
1rude2l's Avatar
Default Re: (1rude2l)
i beleive schlitz was right car stopped moving today left me stranded made a horrible noise i guess the input shaft can go out or something it won't move but the clutch still seems fine......guess have to tear it down
Old Jul 28, 2006 | 03:38 PM
haha ..well that ******* sucks... not hard to change.. if ya know what ur doing...
Old Jul 29, 2006 | 05:17 PM
1rude2l's Avatar
Default Re: (birds_sol_94)
update!!! anybody had problems with act clutch disc apparently mine ripped the splines from the disc that was the whole problem the other day
Old Jul 29, 2006 | 05:33 PM
haha damn thats crazy....!!! id try and exedy clutch... !! very very nice clutch!!
Old Jul 29, 2006 | 05:41 PM
JDM B20 EH2's Avatar
my firts one i broke the contact area on the pressure plate in half but i think it was my fault. i dropped the clutch to do a burn out after drivein for 14 hours. i know i know stupid idea. didnt think and busted it. thats the only prob i have ever had with one. im actually runnin another one now. no probs at all.
kornerk12
Apr 6, 2011 02:01 AM
Speed94
Aug 7, 2008 06:17 AM
Zumo
Mar 3, 2008 07:56 AM
abscher1
Jun 26, 2007 05:57 PM
Andrew 825SM
Nov 21, 2003 12:46 PM
