b16a timing mark
Old Jul 25, 2006 | 02:52 AM
civc_tt's Avatar
Default b16a timing mark
where is the exact timing for the b16a ek4 engine?? in the red or white mark??thanks
Old Jul 25, 2006 | 03:06 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: b16a timing mark (auy_tong2)
both. white is tdc, red is 16 degrees. there are notches on either side of the red that are 14 and 18 degrees.
Old Jul 25, 2006 | 03:09 AM
civc_tt's Avatar
Default Re: b16a timing mark (Rodney)
so if both, then where would i put the pointer? to the red or white???im confused..help
Old Jul 25, 2006 | 06:19 AM
EG2Driver's Avatar
white is TDC. If your cams are at TDC, then put ur crank and TDC, so at the white mark.
Old Jul 25, 2006 | 09:03 PM
civc_tt's Avatar
Default Re: b16a timing mark (DeadEnd9009)
ah ok...when the engine is not running......but im using a timing light....
Kaleb_Johnson
Jul 3, 2014 12:19 PM
enhancedCL9
Apr 26, 2004 08:36 AM
allmotor.net
Nov 8, 2002 08:45 AM
Spoon Si
Sep 8, 2002 11:17 AM
