Car stopped......
Old Jul 25, 2006 | 01:48 AM
sayst's Avatar
Default Car stopped......
I was coming from Los Angeles, CA. But, the car stopped on the highway. My car is 96 Integra LS with light mods. Suddenly, car was turned off on the highway and I just pull over to the side. After that, Car did not start.
A local mechanic in Banning, CA commented as "battery dead, put new battery in and just clicked, checked oil level, no oil registered on dipstick, turned crank & put oil in motor, Car started up with lots of internal engine noise and oil leak, upon further inspention, found oil leaking from left side of engine block, has approx 1 inch hole on engine block, recquire new engine."
My question is that what parts do I need to replace? Defenately, I need engine block. Do you think I should replace head as well? How about T-belt and water pump? Or I am thinkning to buy a complete swap.
I dont know which way is more efficient and cost-saving option. If youguys can help me out, it would be really great!!
Thanks
Old Jul 25, 2006 | 01:53 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Car stopped...... (sayst)
complete swap, It will save you money in the long run. Why rebuild a block to throw a old head on it. Doesn't make sence. When you do your swap put a new timming belt water pump and such so you can start freash.
Old Jul 25, 2006 | 07:21 AM
diesel1245's Avatar
Default Re: Car stopped...... (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">complete swap, It will save you money in the long run. Why rebuild a block to throw a old head on it. Doesn't make sence. When you do your swap put a new timming belt water pump and such so you can start freash. </TD></TR></TABLE>
Old Jul 25, 2006 | 08:53 AM
stocker2shocker91's Avatar
I requested a short story for a title.
no oil light came on?
Old Jul 25, 2006 | 11:49 AM
sayst's Avatar
Default Re: Car stopped...... (stocker2shocker91)
nope.
blue_egsi
14
Jul 27, 2014 06:28 PM
joebmx
19
Sep 15, 2008 05:38 PM
chu77
Aug 5, 2006 08:03 AM
Erod
Oct 3, 2004 01:34 PM
